Sign a certificate from a sperate application with my PKI solution
Can anyone help me with a question. I have a fully implemented and running
Microsoft 2003 Cetificate services solution. As you may know alot of vendors
release there solution as a hardwware based applaince with a Web UI. Most of
them use there own Self Signed certificate. I have one that will allow me to
export and import the certificate. If I export the certificate how do i sign
it with my PKI so my browser will accept the certificate.
Yes I could just generate one and improt it but I wuld like to know how to
do both.
Thanks.
  • Replies 3
Guest S. Pidgorny
Not enough information to answer the question really. Some systems allow
you to generate certificate request for offline submission, others - to
import PKCS #12 file. Most of "appliances" I'm aware of are starndard
Linux or BSD systems running OpenSSL tools and not deviating much from
popular distros (so you'll run openssl req ... to generate cerificate
request); some are Windows-based. Options to install certificates are
there, but the vendor's support might be a different matter.
Svyatoslav Pidgorny, MCSE, RHCE
-= F1 is the key =-
http://sl.mvps.org http://msmvps.com/blogs/sp
Gunna wrote:<span style="color:blue">
> do both.
> Thanks.</span>
Guest Paul Adare - MVP
> it with my PKI so my browser will accept the certificate.</span>
You can't take an existing certificate and have it signed again.
Paul Adare
MVP - Identity Lifecycle Manager
http://www.identit.ca
Guest Alun Jones
"Gunna" <Gunna@discussions.microsoft.com> wrote in message
news:AAE424AA-C135-44A9-90FF-F5580E2052B4@microsoft.com...<span style="color:blue">
> running
> vendors
> of
> to
> sign
> do both.</span>
Think of your request as being akin to this:
I can embed my name and your logo in a block of plastic. I can also ask you
to embed your name and my logo in a block of plastic. How can I take a
block of plastic into which you've embedded your name and logo, and then
embed my own name in there as well?
The answer is that to do that, you have to melt the plastic block to extract
the logo, and then build your own plastic block to embed the logo and name.
Similarly, the process of creating a certificate is that of signing a
Certificate Signing Request (CSR). Note that you are not signing a
Certificate, because a Certificate is already signed. You will have to
either create a new CSR, and then sign it to create a certificate, or find a
way to get the other app to generate a CSR for you to sign.
Alun.
Texas Imperial Software | Web: http://www.wftpd.com/
23921 57th Ave SE | Blog: http://msmvps.com/alunj/
Woodinville WA 98072-8661 | WFTPD, WFTPD Pro are Windows FTP servers.
Fax/Voice +1(425)807-1787 | Try our NEW client software, WFTPD Explorer.
