Guest mikeu Posted October 13, 2008 Posted October 13, 2008 Having problems with e-mail. Whwn I send an e-mail with an attchment it replicates itself multiple times. Then they merge into a single message which when opened looks OK. Takes for ever to download depending on file size. What's going on, help. thanks Quote
Guest Malke Posted October 13, 2008 Posted October 13, 2008 mikeu wrote: <span style="color:blue"> > Having problems with e-mail. Whwn I send an e-mail with an attchment it > replicates itself multiple times. Then they merge into a single message > which when opened looks OK. Takes for ever to download depending on file > size. > What's going on, help. thanks</span> You forgot to tell us what email program you're using, but offhand it sounds as though you have Outlook Express or Windows Mail set to break apart messages over "x" size. If my Crystal Ball� was working, then you can change this setting. Tools>Accounts Highlight your email account. Click Properties and go to the Advanced tab. Make sure "Break apart messages larger than __ KB" is not checked. OK>Close. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ Quote
Guest mikeu Posted October 13, 2008 Posted October 13, 2008 Thanks so much. I'm using outlook. I think you hit it on the nail. I thought I had a virus, found none. "Malke" wrote: <span style="color:blue"> > mikeu wrote: > <span style="color:green"> > > Having problems with e-mail. Whwn I send an e-mail with an attchment it > > replicates itself multiple times. Then they merge into a single message > > which when opened looks OK. Takes for ever to download depending on file > > size. > > What's going on, help. thanks</span> > > You forgot to tell us what email program you're using, but offhand it sounds > as though you have Outlook Express or Windows Mail set to break apart > messages over "x" size. If my Crystal Ball� was working, then you can > change this setting. > > Tools>Accounts > Highlight your email account. > Click Properties and go to the Advanced tab. > Make sure "Break apart messages larger than __ KB" is not checked. > OK>Close. > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > FAQ - http://www.elephantboycomputers.com/#FAQ > > </span> Quote
Guest Malke Posted October 13, 2008 Posted October 13, 2008 mikeu wrote: <span style="color:blue"> > Thanks so much. I'm using outlook. I think you hit it on the nail. > I thought I had a virus, found none.</span> Glad that sorted it for you. Thanks for taking the time to let me know. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ Quote
