system administrator policies prevent installation
Guest trumpeter48
New to Vista, and I get an installer error that states "The system
administrator has set policies to prevent this installation". How do I
change policies to allow installation of other software?
Guest Jimmy Brush
Hello,
- What edition of Vista are you using?
- Are you joined to a domain?
- JB
"trumpeter48" <trumpeter48@discussions.microsoft.com> wrote in message
news:270923EC-E5F2-4A77-A269-BF2854690A0D@microsoft.com...<span style="color:blue">
Guest trumpeter48
I am running Vista Home Premium, not joined to a domain.
I since have found out that if I go to users in the control panel and then
deactivate User Account Control, the issue disappears.
Thanks for your questions.
> Hello,
> - JB
> news:270923EC-E5F2-4A77-A269-BF2854690A0D@microsoft.com...<span style="color:green">
> > </span>
Guest Mick Murphy
You can also right-click on the setup.exe of the program>Run as Admin.
Mad Mike
> > Hello,
> > - JB
> > news:270923EC-E5F2-4A77-A269-BF2854690A0D@microsoft.com...<span style="color:darkred">
> > > </span>
> > </span></span>
Guest trumpeter48
I'll remember that also. If I am logged in as the admin, isn't that good
enough?
> Mad Mike
> > > Hello,
> > > - JB
> > > </span></span></span>
Yes, if you are running as the Administrator, you should be able to install
new software. With UAC on a pop-up will ask for Administrator permission. If
you’re signed in as Administrator all you need to do is mouse click Yes or
Enter in most cases. With some old software that was designed for XP or even
Win 98 you may find it better to install the software using the Program
Compatibility Wizard. More information on this and UAC can be found in the
Start Menu > Help and Support. Also, Vista may have a problem with older
(crummy) software.
Overall, UAC should be turned back on for better system security, especially
if you’re sharing the computer with others, such as family.
oscar style_emoticons/
....Right click is your very good friend...
> enough?
> > Mad Mike
> > > > Hello,
> > > > - JB
  • 1 month later...
Guest Nigel Fieldsend
Hi I am trying to load Dragon naturally speaking 10 onto Vista home
premium and get the message The administrator has set policies to
prevent this installation.
I am the administrator, I have switches off U.A.C. and there is no
setup.exe on the program. This is because there are some prerequisits to
load first. You can use run as administrator to run the prerequisits but
the main program will not follow on and load afterwards.
Have you got any ideas please
Regards
Nigel
Nigel Fieldsend
Nigel Fieldsend's Profile: http://forums.techarena.in/members/nigel-fieldsend.htm
View this thread: http://forums.techarena.in/vista-security/1077124.htm
