Guest PA Bear [MS MVP] Posted December 6, 2008 Posted December 6, 2008 [Forward to Vista Security newsgroup via crosspost] Davis wrote:<span style="color:blue"> > Runing IE7 ver 7.0.6001.18000 on Vista Home Premium SP1 - with Protected > Mode ON, cannot view/listen to any streaming video/audio, cannot downlaod > files, etc. When turn Protected Mode OFF all problems go away. I realize > PM > prevents executables from accessing higher level areas of computer. Only > workaround I've found is going to Tools/Internet Options and un-click PM > check box. Any way to adjust PM so it does not block this content? Or will > MS be adding a dialog box for user to give permission for each instance? > Thanks, Davis </span> Quote
