Handle to PlugPlaySecurityObject was requested, over and over agai
Guest Adam D. Barratt
Hi,
We're in the process of setting up two Windows Server 2008 machines, one to
be a web server and the other an SQL Server. Having enabled auditing on the
machines, the SQL Server is continually logging events such as that below, at
the rate of around 40 every 10 seconds. The process ID referred to is the
DCOM Launcher (svchost.exe -k DcomLaunch). Is there any way to discover why
so many events are being generated and, ideally, stop them being generated?
Thanks,
Adam
Sample event:
A handle to an object was requested.
Subject:
Security ID: SYSTEM
Account Name: MACHINE$
Account Domain: FOOBAR
Logon ID: 0x3e7
Object:
Object Server: PlugPlayManager
Object Type: Security
Object Name: PlugPlaySecurityObject
Handle ID: 0x0
Process Information:
Process ID: 0x318
Process Name: C:\Windows\System32\svchost.exe
Access Request Information:
Transaction ID: {00000000-0000-0000-0000-000000000000}
Accesses: Unknown specific access (bit 1)
Access Mask: 0x2
Privileges Used for Access Check: -
Restricted SID Count: 0
