Newbie AUC Problem
Brand new Vista Ultimate 64 bit user.
I try to open the C: Docs and Settings folder, so I can tweak and edit the
Start Programs layout. I get an "access denied" message.
I'm the sole user on the machine. I was given to understand that this is an
AUC problem. I went to the Security Center, and I thought succeeded in
turning off AUC. But after a restart, I'm still locked out of Docs and
Settings.
If I right click the folder and select Properties | Security |
Administrators, Every Permission except "Special permissions is checked
"allow".
If I go back to the "Turn AUC On/Off" screen, It appears only to offer the
"turn it on" option.
So what's missing? And if I'm the administrator sole user, and can't have
access, then who does have access?
PT
  • Replies 6
On Thu, 1 Jan 2009 15:57:11 -0800, "PT" <xyz@xyz.com> wrote:
>Settings.</span>
As you will ALWAYS be: that is only a shortcut for use by older
programs that aren't Vista-compatible.
>"allow".
>access, then who does have access?</span>
Nobody. Look in C:\Users\your_user_id\Documents.
Don
Guest MowGreen [MVP]
It's UAC and try the Users folders, as in C:\Users\<useraccountname>
Although this KB article refers to an upgrade from XP to Vista, junction
points are why you can not access Docs&Settings:
Error message when you try to access the My Documents, My Music, My
Pictures, and My Videos folders in Windows Vista: "Access is Denied"
http://support.microsoft.com/kb/930128
MowGreen [MVP 2003-2009]
-343- FDNY
Never Forgotten
> Settings.
> "allow".
Maybe I asked the wrong question. This is a brand new Vista machine, not an
upgrade from WinXP.
All I want is simply to open what in Windows XP was the Documents and
Settings| User | Start Menu | Programs folder so I can rearrange, and
consolidate the entries ands subfolders.
PT
"MowGreen [MVP]" <mowgreen@nowandzen.com> wrote in message
news:eC6Z$9GbJHA.4664@TK2MSFTNGP06.phx.gbl...<span style="color:blue">
> It's UAC and try the Users folders, as in C:Users<useraccountname>
> -343- FDNY
> Never Forgotten
> PT wrote:
><span style="color:green">
>> the Start Programs layout. I get an "access denied" message.
>> an AUC problem. I went to the Security Center, and I thought succeeded
>> in turning off AUC. But after a restart, I'm still locked out of Docs
>> and Settings.
>> "allow".
>> the "turn it on" option.
>> have access, then who does have access?
>> </span></span>
> an upgrade from WinXP.
No, you were perfectly clear. But you didn't understand the answers you got.
You can't enter Documents and Settings. Documents and Settings isn't a
real directory in Vista. It's virtual, only there for backwards
compatibility with older software.
The new location in Vista for the all users start menu is:
C:\ProgramData\Microsoft\Windows\Start Menu.
You can click Start and then right-click All Programs and select Explore All
Users and get to the same location.
The user specific start menu folder is in:
C:\Users\username\AppData\Roaming\Microsoft\Windows\Start Menu.
Then you can arrange things as you like.
Malke
MS-MVP
Elephant Boy Computers - Don't Panic!
FAQ - http://www.elephantboycomputers.com/#FAQ
Guest Steve Thackery
PT: read Malke's explanation carefully - it is spot on.
An even quicker way is to right click the Vista Orb, and select 'Explore' or
'Explore all users'.
SteveT
Guest FromTheRafters
"Steve Thackery" <nobody@nowhere.com> wrote in message
news:%23ZyKpzMbJHA.4424@TK2MSFTNGP05.phx.gbl...<span style="color:blue">
> or 'Explore all users'.</span>
Well...she didn't call it the 'orb', but if you read her post
carefully...
style_emoticons/)
