PKI - Issue Publishing to AD DS
Guest Orbital
Hi All!!!
I'm currently implementing 2008 PKI using Brian Komar's excellent book, but
I've run into a few issues. These surfaced when trying to publish my root
and policy CA certs into my AD. On page 133, I'm running an amended piece of
code, with an exert below...
C:\PKI\USB>certutil -dspublish -f "Test Corporate Policy CA.crl"
ldap:///CN=Test Corporate Policy CA,CN=tb2008pki02,CN=CDP,CN=Public Key
Services
,CN=Services,DC=UnavailableConfigDN?certificateRevocationList?base?objectClass=c
RLDistributionPoint?certificateRevocationList
ldap: 0xa: 0000202B: RefErr: DSID-031006E0, data 0, 1 access points
ref 1: 'unavailableconfigdn'
CertUtil: -dsPublish command FAILED: 0x8007202b (WIN32: 8235)
CertUtil: A referral was returned from the server.
Now, I see the problem here
'CN=Services,DC=UnavailableConfigDN?certificateRevocationList'. The question
is, how do I fix it? I've had a scout around and found the following
http://www.derkeiler.com/Newsgroups/micros...8/msg00047.html
In this article, Brian speaks of an incorrect %%6 value in [presumably] the
root CA post install script. But I don't see how I would change this in this
file? And to what value?
Brian's fix, is to run the following command:
certutil -setreg ca\DSConfigDN CN=Configuration,DC=root,DC=example,DC=com
This is understood, [is the DC=root as it is above a fixed value, or is this
just an example of a possible domain name?] but would I then have to revoke
the currently issued cert, and then go through my setup on my policy box
again with the correct new ones?
I'm COMPLETELY new to PKI, so any help is greatly appreciated style_emoticons/
Many thanks in advance,
Orb.
Guest Brian Komar \(MVP\)
You need to replace DC=root,DC=example,DC=com with the LDAP distinguished
name of your forest.
Then it should start working
Brian
"Orbital" <Orbital@discussions.microsoft.com> wrote in message
news:C7AAB6D7-0010-4BA1-9AD1-A440202167D3@microsoft.com...<span style="color:blue">
> Hi All!!!
> but
> of
> C:PKIUSB>certutil -dspublish -f "Test Corporate Policy CA.crl"
> Services
> question
> the
> this
> certutil -setreg caDSConfigDN CN=Configuration,DC=root,DC=example,DC=com
> this
> revoke
> Orb. </span>
Guest Orbital
Hi Brian,
Thanks for your response.
When I look in the 'Published CRL Locations' entry of my root CRL, even on
my rootCA, I see this 'UnavailableConfigDN?' entry:
URL=ldap:///CN=TB2008PKI01-CA,CN=tb2008pki01,CN=CDP,CN=Public%20Key%20Services,CN=Services,DC=UnavailableConfigDN?certificateRevocationList?base?objectClass=cRLDistributionPoint
I'm assuming this is incorrect? But short of amending something on my
rootCA and then reissuing my original cert, I don't see what else I can do?
I thought I'd followed each page in the book to the letter, but it seems I
may have missed something here in my rootCA configuration. My
RootCAPostConfiguration.cmd is below if anyone can find anything wrong? I'm
really stuck here, and may have to rip everything to bits and start all over
again if I cannot get this to work.
Orb.
::Declare Configuration NC
certutil -setreg CA\DSConfigDN CN=Configuration,DC=testad4,DC=test,DC=com
::Define CRL Publication Intervals
certutil -setreg CA\CRLPeriodUnits 26
certutil -setreg CA\CRLPeriod "Weeks"
certutil -setreg CA\CRLDeltaPeriodUnits 0
certutil -setreg CA\CRLDeltaPeriod "Days"
certutil -setreg CA\CRLOverlapPeriod "Weeks"
certutil -setreg CA\CRLOverlapUnits 2
::Apply the required CDP Extension URLs
certutil -setreg CA\CRLPublicationURLs
"1:%windir%\system32\CertSrv\CertEnroll\%%3%%8%%9.crl\n10:ldap:///CN=%%7%%8,CN=%%2,CN=CDP,CN=Public
Key Services,CN=Services,%%6%%10\n 2:http://www.test.com/Certdata/
%%3%%8%%9.crl"
::Apply the required AIA Extension URLs
certutil -setreg CA\CACertPublicationURLs
"1:%windir%\system32\CertSrv\CertEnroll\%%1_%%3%%4.crt\n2:ldap:///CN=%%7,CN=AIA,CN=Public
Key Services,CN=Services,%%6%%11\n
2:http://www.test.com/CertData/%%1_%%3%%4.crt"
::Enable all auditing events for the Test Corporate Root CA
certutil -setreg CA\AuditFilter 127
::Set Validity Period for Issued Certificates
certutil -setreg CA\ValidityPeriodUnits 10
certutil -setreg CA\ValidityPeriod "Years"
:: Enable discrete signatures in subordinate CA certificates
Certutil -setreg CA\csp\DiscreteSignatureAlgorithm 1
::Restart Certificate Services
net stop certsvc & net start certsvc
sleep 5
certutil –crl
::Copy the Root CA certificates and CRLs to the C:\USB folder
Echo Copying Root CA certificate and CRL's to the local C:\USB folder
sleep 5
copy /y %windir%\system32\certsrv\certenroll\ .cr? C:\USB
pause
> Brian
> news:C7AAB6D7-0010-4BA1-9AD1-A440202167D3@microsoft.com...<span style="color:green">
> > Hi All!!!
> > but
> > of
> > Services
> > question
> > the
> > this
> > this
> > revoke
> > Orb. </span>
Guest Orbital
I've also just checked the DSConfigDN entry on my offline policy and root
CA's and this entry is correct: CN=Configuration,DC=testad4,DC=test,DC=com
> Hi Brian,
> Orb.
> certutil -setreg CADSConfigDN CN=Configuration,DC=testad4,DC=test,DC=com
> certutil -setreg CACRLPeriodUnits 26
> certutil -setreg CACRLPeriod "Weeks"
> certutil -setreg CACRLDeltaPeriodUnits 0
> certutil -setreg CACRLDeltaPeriod "Days"
> certutil -setreg CACRLOverlapPeriod "Weeks"
> certutil -setreg CACRLOverlapUnits 2
> certutil -setreg CACRLPublicationURLs
> "1:%windir%system32CertSrvCertEnroll%%3%%8%%9.crln10:ldap:///CN=%%7%%8,CN=%%2,CN=CDP,CN=Public
> Key Services,CN=Services,%%6%%10n 2:http://www.test.com/Certdata/
> %%3%%8%%9.crl"
> certutil -setreg CACACertPublicationURLs
> "1:%windir%system32CertSrvCertEnroll%%1_%%3%%4.crtn2:ldap:///CN=%%7,CN=AIA,CN=Public
> Key Services,CN=Services,%%6%%11n
> certutil -setreg CAAuditFilter 127
> certutil -setreg CAValidityPeriodUnits 10
> certutil -setreg CAValidityPeriod "Years"
> Certutil -setreg CAcspDiscreteSignatureAlgorithm 1
> sleep 5
> certutil –crl
> ::Copy the Root CA certificates and CRLs to the C:USB folder
> Echo Copying Root CA certificate and CRL's to the local C:USB folder
> sleep 5
> copy /y %windir%system32certsrvcertenroll .cr? C:USB
> pause
> > Brian
> > news:C7AAB6D7-0010-4BA1-9AD1-A440202167D3@microsoft.com...<span style="color:darkred">
> > > Hi All!!!
> > > but
> > > of
> > > Services
> > > question
> > > the
> > > this
> > > this
> > > revoke
> > > Orb. </span>
> > </span></span>
Guest Orbital
Sorry to bombard this thread with messages but, running through the cert
publishing to my AD DC via CMD again, I see
Possible Root Certificate: Subject matches Issuer, but Signature check
fails: 80090008
I'm thinking this doesn't help...
Hi,
This is definitely an incorrect configuration.
You need to check two separate objects issued by the root CA.
1) The CRL. If the CRL does not have the correct location, you need to
ensure that the post -configuration script on the root CA correctly ran the
command.
One common mistake (seeing that you have copied the text directly from my
book <G>) is that you copied direct from the PDF and the (-) character is
translated to an m-dash. If you do a certutil -getreg ca\DSConfigDN at the
root CA, what value is shown? Ensure that it matches the defined DN, and
then publish a new CRL. You must publish a new CRL before it will read the
new DN value and replace the %%6 value in the CRLPublicationURLs registry
entry.
2) The subordinate CA certificates. Since you include the LDAP URL in your
subordinate CA certificate issued by the root CA, look at the AIA extension
of the subordinate CA certificate. Does the URL show up as the correct DN or
as UnavailableConfigDN. If it Unavailable ConfigDN, then you will have to
re-issue the subordinate CA certificate (and all other lower certificates).
Brian
news:E1D5706E-4E2C-4F7C-9881-CBB90A47217A@microsoft.com...<span style="color:blue">
> Hi Brian,
> my rootCA, I see this 'UnavailableConfigDN?' entry:Hi
> do?
> I'm
> over
> Orb.
> %%3%%8%%9.crl"
> sleep 5
> certutil –crl
> sleep 5
> pause
>> Brian
>> > Hi All!!!
>> > but
>> > root
>> > piece
>> > of
>> > Services
>> > question
>> > the
>> > in
>> > this
>> > this
>> > revoke
>> > box
>> > Orb.</span>
>> </span></span>
Guest Orbital
Hi Brian,
Thanks for replying.
I'm positive I've completed everything correctly. It's not even a
copy/paste character problem as I used the examples from the 'Resources'
folder on the CD.
I've actually logged a call with your friends at Microsoft regarding this,
who are equally baffled. We've modified [and even removed] LDAP entries,
reissued, revoked and allsorts, to no effect. My case is being worked on and
I'll wait to hear.
Thanks for your input Brian.
Orb.
  • 1 month later...
Hi Orb,
Did you get this fixed becuase i just had the same issue this morning.
The scripts etc.. were correct but i had to manually delete the .crl
from the Windows\System32\CertSrv\CertEnroll folder and then re-generate
it using the certificates management console (right click publish on the
"revoked" node)
Ben.
