Guest Neil Jones Posted January 13, 2009 Posted January 13, 2009 I am trying to turn off the display after 30 minutes of inactivity. But nothing seems to be changing. As administrator, it works fine. On Vista, can a normal user change the Power Options? NJ Quote
Guest Wim Hekken ;-) Posted January 13, 2009 Posted January 13, 2009 Neil Jones asked the following question in:<span style="color:blue"> > I am trying to turn off the display after 30 minutes of inactivity. But > nothing seems to be changing. As administrator, it works fine. On > Vista, can a normal user change the Power Options? > > NJ</span> Are your power settings in your BIOS set to the right values? Read the manual of the motherboard for the correct settings. -- Wim Hekken ;-) Carpe Diem Quote
Guest Neil Jones Posted January 14, 2009 Posted January 14, 2009 Wim Hekken ;-) wrote:<span style="color:blue"> > Neil Jones asked the following question in:<span style="color:green"> >> I am trying to turn off the display after 30 minutes of inactivity. But >> nothing seems to be changing. As administrator, it works fine. On >> Vista, can a normal user change the Power Options? >> >> NJ</span> > > Are your power settings in your BIOS set to the right values? Read the > manual of the motherboard for the correct settings.</span> I do not know about the BIOS settings, but I know the power settings are working for the Administrator account but not to the regular user accounts. Why? NJ PS - I never had to deal with the BIOS level setting for power savings. Quote
Guest Ian D Posted January 14, 2009 Posted January 14, 2009 "Neil Jones" <castellan2004-nschap@remove-this.yahoo.com> wrote in message news:O3mequXdJHA.5904@TK2MSFTNGP03.phx.gbl...<span style="color:blue"> >I am trying to turn off the display after 30 minutes of inactivity. But > nothing seems to be changing. As administrator, it works fine. On > Vista, can a normal user change the Power Options? > > NJ</span> A normal user can change the display power settings. Power settings are global, when one user changes them, the change applies to all users, including administrators. You are clicking the Save Changes button? Quote
Guest Neil Jones Posted January 16, 2009 Posted January 16, 2009 Ian D wrote:<span style="color:blue"> > "Neil Jones" <castellan2004-nschap@remove-this.yahoo.com> wrote in message > news:O3mequXdJHA.5904@TK2MSFTNGP03.phx.gbl...<span style="color:green"> >> I am trying to turn off the display after 30 minutes of inactivity. But >> nothing seems to be changing. As administrator, it works fine. On >> Vista, can a normal user change the Power Options? >> >> NJ</span> > > A normal user can change the display power settings. Power > settings are global, when one user changes them, the change > applies to all users, including administrators. You are clicking > the Save Changes button? > > </span> Thank you for replying. Yes, I am saving the changes after modifying the power settings. It is only working for the Administrator. For regular user accounts the display is left on all the time regardless what I set it to in the power settings. I am using Vista Ultimate. Hopefully someone from Microsoft is reading this. NJ Quote
