Guest dfinc Posted January 23, 2009 Posted January 23, 2009 Heres free spyware guad 2008 manual removal guide for those who are infected by this rogue spyware as it has infected millions of computers. Spyware Guard 2008, also known as SpywareGuard 2008 or SpywareGuard2008, is new counterfeit anti-spyware software that created to invade yoru privacy and ruin the Internet community. Just like most fake antispywares, Spyware Guard 2008 issues misleading and exaggerated results. Spyware Guard 2008 usually installed itself onto your PC without your permission, through Vundo Trojan, Virus or fake software. SpywareGuard2008 will display fake system alerts or fake security alerts to trick user to buy the paid version of SpywareGuard2008 , in order to remove the potential and reported problems. Not only does it cause your machine to slow down dramatically, it would also put your privacy and data in risk. To remove spyware guard manualy, follow the instructions given at http://darfuns.com/remove-spyware-guard-2008/ Quote
Guest Kayman Posted January 23, 2009 Posted January 23, 2009 Re: Spyware-guard 2008 removal guide! How to remove spyware guard 2008 manually On Thu, 22 Jan 2009 20:31:19 -0800 (PST), dfinc wrote: <span style="color:blue"> > Heres free spyware guad 2008 manual removal guide for those who are > infected by this rogue spyware as it has infected millions of > computers.</span> And here is a fine scanner which will remove this as well: Malwarebytes© Corporation - Anti-Malware http://www.malwarebytes.org/mbam/program/mbam-setup.exe Quote
Guest PA Bear [MS MVP] Posted January 23, 2009 Posted January 23, 2009 Re: Spyware-guard 2008 removal guide! How to remove spyware guard 2008 manually SPAM! Click on that link & you're gonna have problems. See http://www.siteadvisor.com/sites/darfuns.com -- ~Robear Dyer (PA Bear) MS MVP-IE, Mail, Security, Windows Desktop Experience - since 2002 AumHa VSOP & Admin http://aumha.net DTS-L http://dts-l.net/ dfinc wrote:<span style="color:blue"> > Heres free spyware guad 2008 manual removal guide for those who are > infected by this rogue spyware as it has infected millions of > computers.... > To remove spyware guard manualy, follow the instructions given at > XXXXdarfuns.com/remove-spyware-guard-2008/ </span> Quote
