Guest Brian Stoop Posted February 3, 2009 Posted February 3, 2009 Hi, I have Vista Business and Vista Home laptops. The "Sharing and Discovery" settings in "Network and Sharing Centre" are identical. When I try to run net use \\ipaddress\IPC$ /USER:administrator password on the VISTA BUSINESS machine it works. but on the VISTA HOME machine I get: "System error 1385 has occurred. Logon failure: the user has not been granted the requested logon type at this computer." Is this a security feature or restriction of VISTA HOME and is there a way to map to the IPC$ share ? thanks, B Quote
