Guest viglen Posted February 15, 2009 Posted February 15, 2009 Hi, I'm using VB6 PDW and Deploying the installation files with "WinZip Self Extractor". I noticed that the "WinZip Self Extractor" has a wonderful feature of starting and running the "setup.exe" of the installation in Vista as a Administrator, if you wish to choose this option. I really need my software to install and run as an administrator in my clients' Vista machines otherwise some features will not work. The question is: If I make sure the Setup.exe is ran as Administrator, so the software installation process runs as administrator, does that mean that the software will be installed as an administrator ? If not, please give me some ideas of how do I achieve the need for my installations to install the software I develop to run as an administrator (I know I can instruct my clients to right click on the software's short cut and select properties and select "Always Run As administrator", but what is the automated way of doing this in installation, to make it easy and automated?) Thank you. Quote
Guest Sam Hobbs Posted February 16, 2009 Posted February 16, 2009 Re: Using VB6 PDW & Deploying with "WinZip Self Extractor", I need to install in a way that software Runs as Administrator for Vista. Ask in a developer's newsgroup, such as: microsoft.public.platformsdk.security microsoft.public.platformsdk.msi microsoft.public.vb.general.discussion There are probably others that are useful and relevant, so you should look for yourself too. "viglen" <AlexandriaSupport@gmail.com> wrote in message news:a24b3598-016d-4624-9a1f-9cf5600b1abb@g38g2000yqd.googlegroups.com...<span style="color:blue"> > Hi, > > I'm using VB6 PDW and Deploying the installation files with "WinZip > Self Extractor". > > I noticed that the "WinZip Self Extractor" has a wonderful feature of > starting and running the "setup.exe" of the installation in Vista as a > Administrator, if you wish to choose this option. > > I really need my software to install and run as an administrator in my > clients' Vista machines otherwise some features will not work. > > The question is: If I make sure the Setup.exe is ran as Administrator, > so the software installation process runs as administrator, does that > mean that the software will be installed as an administrator ? > > If not, please give me some ideas of how do I achieve the need for my > installations to install the software I develop to run as an > administrator (I know I can instruct my clients to right click on the > software's short cut and select properties and select "Always Run As > administrator", but what is the automated way of doing this in > installation, to make it easy and automated?) > > Thank you. </span> Quote
