Guest Rich Posted February 20, 2009 Posted February 20, 2009 Hi, I am trying to find out if I can use VBScript/WMI to read the information contained within a certificate. Using Scriptomatic, I get the following script, but nothing is returned: On Error Resume Next Const wbemFlagReturnImmediately = &h10 Const wbemFlagForwardOnly = &h20 arrComputers = Array("localhost") For Each strComputer In arrComputers WScript.Echo WScript.Echo "==========================================" WScript.Echo "Computer: " & strComputer WScript.Echo "==========================================" Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\ServiceModel") Set colItems = objWMIService.ExecQuery("SELECT FROM ClientCredentials", "WQL", _ wbemFlagReturnImmediately + wbemFlagForwardOnly) Wscript.Echo "Starting now..." For Each objItem In colItems WScript.Echo "ClientCertificate: " & objItem.ClientCertificate WScript.Echo "HttpDigest: " & objItem.HttpDigest WScript.Echo "IssuedToken: " & objItem.IssuedToken WScript.Echo "Peer: " & objItem.Peer WScript.Echo "ServiceCertificate: " & objItem.ServiceCertificate WScript.Echo "SupportInteractive: " & objItem.SupportInteractive WScript.Echo "Type: " & objItem.Type WScript.Echo "UserName: " & objItem.UserName WScript.Echo "Windows: " & objItem.Windows WScript.Echo Next Next WScript.Echo "Execution is now complete." Can anyone tell me how to accomplish this? Solution need not be limited to WMI. I actually prefer straight VBScript. TIA, Rich Quote
