Guest Andrew Posted February 26, 2009 Posted February 26, 2009 Hi, There, I'm run automation in Windows Server 2008, DEP blocked my program everytime i run it. I have another two machines with the same hardware, windows server 2008 installed. There is no problem when those automation program run at the other two machines. i tried to exclude my automation program from exclusion, but not allowed. I also tried to turn on DEP for essential programs only, failed. Anyone can help me? Quote
Guest Drezpc Posted March 22, 2009 Posted March 22, 2009 Andrew - try the BCDEdit command The /set command sets a boot entry option value in the boot configuration data store. Use this command to configure specific boot entry elements, such as kernel debugger settings, data execution protection (DEP) and processor address extension (PAE) options, and to load alternate hardware abstraction layer (HAL) and kernel files. "Andrew" <Andrew@discussions.microsoft.com> wrote in message news:59479D71-A2E1-4C18-9E5A-FABF896AD7B3@microsoft.com...<span style="color:blue"> > Hi, There, > I'm run automation in Windows Server 2008, DEP blocked my program > everytime > i run it. > I have another two machines with the same hardware, windows server 2008 > installed. There is no problem when those automation program run at the > other > two machines. > > i tried to exclude my automation program from exclusion, but not allowed. > I also tried to turn on DEP for essential programs only, failed. > > Anyone can help me? </span> Quote
