Guest BAL007 Posted March 27, 2009 Posted March 27, 2009 This is not a joke! I started to hear sporadically some music and voice on my PC, like if I was listening to a radio station; I have no such application on my system. When this is happening, only ordinary applications (like Outlook or Word) are running. Stopping all the applications does not make any difference. When it happens, I have noticed that a process called 17134.exe is running and is consuming quite a lot of memory space. At start-up of my system, the original memory space used by that process is around 2000K but when I start hearing the sounds, the amount of memory used is around 58000K and varying; it uses between 10 to 30% of CPU. If I stop the process, the situation goes back to normal, no more sounds. The description of the process is “Unload PerfMon Countersâ€Â. I looked for a file named 17134.exe on my disk but there is no such file. When I start my system, I have a window with an error message: 17134.exe application error, click OK to terminate the program. The process is recreated automatically. I make sure that my anti-virus is always up-to-date and I ran a full scan on my system. Nothing unusual was detected. I would like to know if that process is legitimate, and why it behaves like that. Any thoughts? Quote
Guest Bruce Chambers Posted March 27, 2009 Posted March 27, 2009 BAL007 wrote:<span style="color:blue"> > This is not a joke! I started to hear sporadically some music and voice on my > PC, like if I was listening to a radio station; I have no such application on > my system. When this is happening, only ordinary applications (like Outlook > or Word) are running. Stopping all the applications does not make any > difference. When it happens, I have noticed that a process called 17134.exe > is running and is consuming quite a lot of memory space. At start-up of my > system, the original memory space used by that process is around 2000K but > when I start hearing the sounds, the amount of memory used is around 58000K > and varying; it uses between 10 to 30% of CPU. If I stop the process, the > situation goes back to normal, no more sounds. The description of the process > is “Unload PerfMon Countersâ€Â. I looked for a file named 17134.exe on my disk > but there is no such file. When I start my system, I have a window with an > error message: 17134.exe application error, click OK to terminate the > program. The process is recreated automatically. I make sure that my > anti-virus is always up-to-date and I ran a full scan on my system. Nothing > unusual was detected. I would like to know if that process is legitimate, and > why it behaves like that. Any thoughts?</span> The file "17134.exe" is most certainly not legitimate, and is a sure sign that whatever anti-virus application you're using is not adequate protection. Not that the file is necessarily a virus, per se, but it is certainly not a welcome addition to your system. What other anti-malware measures have you taken? Remember, there are several types of malware, and many of them are not detected by purely anti-virus applications. As you're getting an error message that clearly indicates that the program is trying to initiate each time you start Windows, the first thing you should do is use MSConfig to determine how the file program is starting, and where it's located. This Knowledge Base Article refers to WinXP, but the same principles apply in Vista: How to Troubleshoot By Using the Msconfig Utility in Windows XP http://support.microsoft.com/default.aspx?...kb;EN-US;310560 Remember, Msconfig was designed to be a troubleshooting tool, not a "startup configurer." Use MSConfig to determine the location of the command that is attempting to start the program, and remove it. To cease the selective startup notifications, either return your settings to the way they were, or permanently remove the undesirable programs from your startup configuration. Additionally, in Vista, Windows Defender can be used to monitor/control Startup programs. To use Windows Defender, click the Orb > Control Panel > Windows Defender > Tools > Software Explorer and select the "Startup Programs" category. Additionally, AutoRuns from Sysinternals is a bit more complicated, but it'll provide the same (and much more) information and capabilities: http://www.microsoft.com/technet/sysintern...n/Autoruns.mspx I'd also have to conclude that the reason you've failed, so far, to find the file is that you've unwisely left Windows Explorer's default settings, and haven't re-enabled the capabilities to see and search for hidden or "system" files. -- Bruce Chambers Help us help you: http://www.catb.org/~esr/faqs/smart-questions.html http://support.microsoft.com/default.aspx/kb/555375 They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. ~Benjamin Franklin Many people would rather die than think; in fact, most do. ~Bertrand Russell The philosopher has never killed any priests, whereas the priest has killed a great many philosophers. ~ Denis Diderot Quote
Guest avgwarhawk Posted March 27, 2009 Posted March 27, 2009 The file "17134.exe" is most certainly not legitimate, and is a sure sign that whatever anti-virus application you're using is not adequate protection. Not that the file is necessarily a virus, per se, but it is certainly not a welcome addition to your system. What other anti-malware measures have you taken? Remember, there are several types of malware, and many of them are not detected by purely anti-virus applications. As you're getting an error message that clearly indicates that the program is trying to initiate each time you start Windows, the first thing you should do is use MSConfig to determine how the file program is starting, and where it's located. This Knowledge Base Article refers to WinXP, but the same principles apply in Vista: How to Troubleshoot By Using the Msconfig Utility in Windows XP '_http://support.microsoft.com/default...b;EN-US;310560_' (http://support.microsoft.com/default.aspx?...kb;EN-US;310560) Remember, Msconfig was designed to be a troubleshooting tool, not a "startup configurer." Use MSConfig to determine the location of the command that is attempting to start the program, and remove it. To cease the selective startup notifications, either return your settings to the way they were, or permanently remove the undesirable programs from your startup configuration. Additionally, in Vista, Windows Defender can be used to monitor/control Startup programs. To use Windows Defender, click the Orb > Control Panel > Windows Defender > Tools > Software Explorer and select the "Startup Programs" category. Additionally, AutoRuns from Sysinternals is a bit more complicated, but it'll provide the same (and much more) information and capabilities: '_http://www.microsoft.com/technet/sys.../Autoruns.mspx_' (http://www.microsoft.com/technet/sysintern...n/Autoruns.mspx) I'd also have to conclude that the reason you've failed, so far, to find the file is that you've unwisely left Windows Explorer's default settings, and haven't re-enabled the capabilities to see and search for hidden or "system" files. -- avgwarhawk Quote
Guest peter Posted March 28, 2009 Posted March 28, 2009 Hey. .its an echo! Must be reverberating from his empty head peter -- If you find a posting or message from me offensive,inappropriate or disruptive,please ignore it. If you dont know how to ignore a posting complain to me and I will be only too happy to demonstrate :-) "avgwarhawk" <guest@unknown-email.com> wrote in message news:e76274f08ced247148f17db82f260df4@nntp-gateway.com...<span style="color:blue"> > > The file "17134.exe" is most certainly not legitimate, and is a sure > sign that whatever anti-virus application you're using is not adequate > protection. Not that the file is necessarily a virus, per se, but it is > certainly not a welcome addition to your system. What other > anti-malware measures have you taken? Remember, there are several types > of malware, and many of them are not detected by purely anti-virus > applications. > > As you're getting an error message that clearly indicates that the > program is trying to initiate each time you start Windows, the first > thing you should do is use MSConfig to determine how the file program > is > starting, and where it's located. > > This Knowledge Base Article refers to WinXP, but the same > principles apply in Vista: > > How to Troubleshoot By Using the Msconfig Utility in Windows XP > '_http://support.microsoft.com/default...b;EN-US;310560_' > (http://support.microsoft.com/default.aspx?...kb;EN-US;310560) > > Remember, Msconfig was designed to be a troubleshooting tool, not a > "startup configurer." Use MSConfig to determine the location of the > command that is attempting to start the program, and remove it. To > cease the selective startup notifications, either return your settings > to the way they were, or permanently remove the undesirable programs > from your startup configuration. > > Additionally, in Vista, Windows Defender can be used to > monitor/control Startup programs. To use Windows Defender, click the > Orb > Control Panel > Windows Defender > Tools > Software Explorer and > select the "Startup Programs" category. > > Additionally, AutoRuns from Sysinternals is a bit more complicated, > but it'll provide the same (and much more) information and > capabilities: > > '_http://www.microsoft.com/technet/sys.../Autoruns.mspx_' > (http://www.microsoft.com/technet/sysintern...n/Autoruns.mspx) > > > I'd also have to conclude that the reason you've failed, so far, to > find the file is that you've unwisely left Windows Explorer's default > settings, and haven't re-enabled the capabilities to see and search for > hidden or "system" files. > > > -- > avgwarhawk </span> Quote
Guest Malke Posted March 28, 2009 Posted March 28, 2009 BAL007 wrote: <span style="color:blue"> > This is not a joke! I started to hear sporadically some music and voice on > my PC, like if I was listening to a radio station; I have no such > application on > my system. When this is happening, only ordinary applications (like > Outlook or Word) are running. Stopping all the applications does not make > any difference. When it happens, I have noticed that a process called > 17134.exe is running and is consuming quite a lot of memory space. At > start-up of my system, the original memory space used by that process is > around 2000K but when I start hearing the sounds, the amount of memory > used is around 58000K and varying; it uses between 10 to 30% of CPU. If I > stop the process, the situation goes back to normal, no more sounds. The > description of the process is ?Unload PerfMon Counters?. I looked for a > file named 17134.exe on my disk but there is no such file. When I start my > system, I have a window with an error message: 17134.exe application > error, click OK to terminate the program. The process is recreated > automatically. I make sure that my anti-virus is always up-to-date and I > ran a full scan on my system. Nothing unusual was detected. I would like > to know if that process is legitimate, and > why it behaves like that. Any thoughts?</span> As the others have told you, your computer is probably infected. Scanning with an antivirus (which one?) isn't adequate. Go through these general malware removal steps systematically - http://www.elephantboycomputers.com/page2....emoving_Malware Include scanning with David Lipman's Multi_AV and follow instructions to do all scans in Safe Mode. Please see the special Notes regarding using Multi_AV in Vista. http://www.elephantboycomputers.com/page2.html#Multi-AV - instructions http://tinyurl.com/yoeru3 - download link and more instructions When all else fails, get guided help. Choose one of the specialty forums listed at the first link. Register and read its posting FAQ. PLEASE DO NOT POST LOGS IN THE MS NEWSGROUPS. If you can't do the work yourself (and there is no shame in admitting this isn't your cup of tea), take the machine to a professional computer repair shop (not your local equivalent of BigComputerStore/GeekSquad). Please be aware that not all local shops are skilled at removing malware and even if they are, your computer may be so infested that Windows will need to be clean-installed. If possible, have all your data backed up before you take the machine into a shop. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ Quote
Guest CarbonMonoxide Posted April 16, 2009 Posted April 16, 2009 BAL007;1004506 Wrote: <span style="color:blue"> > This is not a joke! I started to hear sporadically some music and voice > on my > PC, like if I was listening to a radio station; I have no such > application on > my system. When this is happening, only ordinary applications (like > Outlook > or Word) are running. Stopping all the applications does not make any > difference. When it happens, I have noticed that a process called > 17134.exe > is running and is consuming quite a lot of memory space. At start-up of > my > system, the original memory space used by that process is around 2000K > but > when I start hearing the sounds, the amount of memory used is around > 58000K > and varying; it uses between 10 to 30% of CPU. If I stop the process, > the > situation goes back to normal, no more sounds. The description of the > process > is “Unload PerfMon Countersâ€Â. I looked for a file named 17134.exe > on my disk > but there is no such file. When I start my system, I have a window with > an > error message: 17134.exe application error, click OK to terminate the > program. The process is recreated automatically. I make sure that my > anti-virus is always up-to-date and I ran a full scan on my system. > Nothing > unusual was detected. I would like to know if that process is > legitimate, and > why it behaves like that. Any thoughts?</span> That has started to happen to my laptop as well. Out of the blue ill just hear some drum and bass music or some radio broadcast about Barrack Obama. Have you found a process called any files called TargetWeb on your computer by any chance? Cause ive found that on mine -- CarbonMonoxide http://carbonmonoxidemusic.myfastforum.org/index.php Quote
