Guest alpha Posted March 28, 2009 Posted March 28, 2009 Hi, well, I did encrypt some folders and after some time decrypted them. Now I have a problem with using Search - when it tries to access the _ ex -encrypted_ files, it hangs off and a pop-up window says: "Encrypting File System" Wrote: <span style="color:blue"> > You are encrypting a file or trying to access an encrypted file using a > smart card. Enter your smart card PIN.</span> Well, that was out of the blue! I've never even HEARD about smart cards for encryption! Any known solution for this? -- alpha Quote
Guest alpha Posted March 28, 2009 Posted March 28, 2009 I have to note that other user accounts can access these files properly and the search function is not screwed there. -- alpha Quote
Guest alpha Posted April 3, 2009 Posted April 3, 2009 I have to note that other user accounts can access these files properly and the search function is not screwed there. -- alpha Quote
