Guest Kasparov Posted May 1, 2009 Posted May 1, 2009 I am facing a weird problem. Any pointers are much appreciated. I am using SSPI for authentication on Windows 2003 machine. On my server side I am checking whether my SSPI context user is part of the backup operators (BO) group. Now the check always returns me false even though the user is present in the BO group on that machine. Strange thing is if I do logonuser using the same username and password (with which the client is running) on the server side and try to check whether the logon user token is part of the BO group it returns me TRUE ! Have also tried with administrator group but there the functionality is as expected (both the times it returns me true) . So I am not sure whats going on. I am pasting part of my code below: // At this point SSPI handshake is complete. AcceptSecurityContext has returned 0. // Initialise SID for the Backup Operators group if ( AllocateAndInitializeSid( &NtAuthority, 2, SECURITY_BUILTIN_DOMAIN_RID, DOMAIN_ALIAS_RID_BACKUP_OPS, 0, 0, 0, 0, 0, 0, &BOGroup ) == 0) { ret_val = GetLastError(); break; } // Impersonate the context ss = ( c->ImpersonateSecurityContext)(&c->hContext); if (!SEC_SUCCESS(ss)) { ret_val = E_CORBA_AUTH_FAILURE; break; } // Fetch username with domain name from the SSPI context HANDLE hToken = NULL; PTOKEN_USER ptiUser = NULL; DWORD cbti = 0; SID_NAME_USE snu; // Check group permissions if (!CheckTokenMembership( NULL, BOGroup, &bIsMember)) // Check whether part of the BO group { ret_val = GetLastError(); break; } if (bIsMember) { sspiContext.isBO = true; } else { } // Do Logon user with the same credentials and impersonate to fetch the access token // here NDMPContext.username and password are of the same user as obtained from SSPI context. LogonAndImpersonateUser( (const CHAR ) (ndmpContext.username).c_str(), (const CHAR ) (ndmpContext.passsword).c_str() ); if (!CheckTokenMembership( NULL, BOGroup, &bIsMember)) { BE_Zprintf(0, TEXT("checkGroupMembership: CheckTokenMembership returned %d\n"), GetLastError() ); } if ( ndmpContext.isAnonymous || ( !ndmpContext.isAdmin && ! ndmpContext.isBO )) { BE_Zprintf( 0, TEXT( "SSPIAuthenticate: Authenticating user is ANONYMOUS or not part of the administrator / BO group. Rejecting..." )); ret_val = E_CORBA_AUTH_FAILURE; break; } Thanks in advance, Ganesh Tambat Quote
