Guest KSC Posted September 11, 2009 Posted September 11, 2009 Dear, I try to install IE 8 through WSUS on Windows XP SP2 clients, but without success, is the error in the log file the cause? ERROR: Couldn't read value: 'LIPPackage' from [Version] section in update.inf 00:00.000: ==================================================================== 00:00.125: Started: 2009/09/10 (Y/M/D) 14:52:38.075 (local) 00:00.140: Time Format in this log: MM:ss.mmm (minutes:seconds.milliseconds) 00:00.156: Command line: f:\8accc5038729beaaae0194\update\iesetup.exe /wu-silent 00:00.187: INFO: Checking version for f:\8accc5038729beaaae0194\update\iesetup.exe: 8.0.6001.18702 00:00.296: INFO: Acquired Package Installer Mutex 00:00.312: INFO: Operating System: Windows Workstation: 5.1.2600 (Service Pack 2) 00:00.515: ERROR: Couldn't read value: 'LIPPackage' from [Version] section in update.inf 00:00.531: INFO: Checking Prerequisites 00:00.562: INFO: Checking version for C:\WINDOWS\system32\msctf.dll: 5.1.2600.2180 00:00.578: INFO: Prerequisites Satisfied: No 00:00.640: INFO: Checking version for C:\Program Files\Internet Explorer\iexplore.exe: 7.0.6000.16876 00:00.671: INFO: C:\Program Files\Internet Explorer\iexplore.exe version: 7.0.6000.16876 00:00.687: INFO: Checking if iexplore.exe's current version is between 8.0.6001.0... 00:00.718: INFO: ...and 8.1.0.0... 00:00.734: INFO: Maximum version on which to run IEAK branding is: 8.1.0.0... 00:00.750: INFO: iexplore.exe version check success. Install can proceed. 00:00.781: INFO: Checking version for C:\Program Files\Internet Explorer\iexplore.exe: 7.0.6000.16876 00:00.796: INFO: Checking version for C:\WINDOWS\system32\mshtml.dll: 7.0.6000.16890 00:00.828: INFO: Checking version for C:\WINDOWS\system32\wininet.dll: 7.0.6000.16876 00:00.906: INFO: EULA not shown in passive or quiet mode. 00:00.937: INFO: Skip directly to Options page. 00:01.000: INFO: |PreInstall >>> CPageProgress::DlgProc: Exiting Phase PH_NONE 00:01.015: INFO: |PreInstall >>> CPageProgress::_ChangeState: Original Phase: 0 00:01.031: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 00:01.062: INFO: |Initialize >>> <span style="color:blue"> >[bEGIN]------------------------------</span> 00:01.078: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 00:01.093: INFO: |Initialize >>> SKIP[FALSE]>>Looking for skip clauses 00:01.125: INFO: |Initialize >>> SKIP[FALSE]>>Result: RUNNING This Phase 00:01.140: INFO: |Initialize >>> Calculating bytes needed to install. 00:01.171: INFO: |Initialize >>> Diskspace Required: 151918308 00:01.187: INFO: |Initialize >>> Diskspace Available to user: 26173431808 00:01.265: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: CoCreateInstance.CLSID_UpdateSession: HResult 0x00000000 00:01.296: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: PutClientApplicationID: HResult 0x00000000 00:01.312: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: CreateUpdateSearcher: HResult 0x00000000 00:01.343: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: CreateUpdateDownloader: HResult 0x00000000 00:01.359: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: CreateUpdateInstaller: HResult 0x00000000 00:01.375: INFO: WindowsUpdate>>WindowsUpdateMgr::Initialize: State Change: SS_INITIALIZED. 00:01.406: INFO: |Initialize >>> CStateInitialize::OnInitialize: Windows Update Manager Initialization Result: 0x00000000 00:01.421: INFO: |Initialize >>> CInstallationState::_ExitState: Preparing to Leave State. 00:01.437: INFO: |Initialize >>> CInstallationState::_ExitState: Setting Progress 100. 00:01.468: INFO: |Initialize >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 00:01.484: INFO: |Initialize >>> CInstallationState::_ExitState: Posting Exit Phase Message. 00:01.500: INFO: |Initialize >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 00:01.531: INFO: |Initialize >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 00:01.546: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 00:01.578: INFO: |Initialize >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 00:01.593: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: Actual Phase: 1 00:01.609: INFO: |Initialize >>> <[END]-------------------------------- 00:01.625: INFO: |Initialize >>> CPageProgress::_ChangeState: Original Phase: 1 00:01.656: INFO: |Uninstall Prev. >>> <span style="color:blue"> >[bEGIN]------------------------------</span> 00:01.671: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: Actual Phase: 2 00:01.687: INFO: |Uninstall Prev. >>> SKIP[FALSE]>>Looking for skip clauses 00:01.718: INFO: |Uninstall Prev. >>> SKIP[FALSE]>> Adding [FALSE] Condition: !_psdStateData->GetIsInitSuccessful() 00:01.734: INFO: |Uninstall Prev. >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !g_pApp->GetState()->AreWeDoingUninstall() 00:01.750: INFO: |Uninstall Prev. >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 00:01.781: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Preparing to Leave State. 00:01.796: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Setting Progress 100. 00:01.812: INFO: |Uninstall Prev. >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 00:01.843: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Posting Exit Phase Message. 00:01.859: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 00:01.875: INFO: |Uninstall Prev. >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 00:01.906: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: Actual Phase: 2 00:01.921: INFO: |Uninstall Prev. >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 00:01.937: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: Actual Phase: 2 00:01.968: INFO: |Uninstall Prev. >>> <[END]-------------------------------- 00:01.984: INFO: |Uninstall Prev. >>> CPageProgress::_ChangeState: Original Phase: 2 00:02.000: INFO: |WU Download >>> <span style="color:blue"> >[bEGIN]------------------------------</span> 00:06.609: INFO: |Inst. Post-Upd. >>> <span style="color:blue"> >[bEGIN]------------------------------</span> 00:06.625: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 10 00:06.656: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>>Looking for skip clauses 00:06.671: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>> Adding [FALSE] Condition: !_psdStateData->GetIsInitSuccessful() 00:06.687: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>> Adding [FALSE] Condition: !g_pApp->GetState()->GetOptShouldUpdate() 00:06.718: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetResultCouldInstallIE() 00:06.734: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetResultPostIEUpdateState()!=WU_COULD_DOWNLOAD 00:06.750: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING 00:06.781: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 00:06.796: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 00:06.812: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 00:06.843: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Preparing to Leave State. 00:06.859: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Setting Progress 100. 00:06.875: INFO: |Inst. Post-Upd. >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 00:06.906: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Posting Exit Phase Message. 00:06.921: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 00:06.937: INFO: |Inst. Post-Upd. >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 00:06.968: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 10 00:06.984: INFO: |Inst. Post-Upd. >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 00:07.000: INFO: Setting Windows Update Registry Keys: LookingForUpdates=0x00 - ForcePostUpdateDownload=0x00 - ForcePostUpdateInstall=0x00 00:07.031: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: Actual Phase: 10 00:07.046: INFO: |Inst. Post-Upd. >>> <[END]-------------------------------- 00:07.062: INFO: |Inst. Post-Upd. >>> CPageProgress::_ChangeState: Original Phase: 10 00:07.093: INFO: |IEAK After IEUPD >>> <span style="color:blue"> >[bEGIN]------------------------------</span> 00:07.109: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: Actual Phase: 11 00:07.125: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>>Looking for skip clauses 00:07.156: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>> Adding [FALSE] Condition: !_psdStateData->GetIsInitSuccessful() 00:07.171: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetOptIEAKMode()!=IEAK_PACKAGE 00:07.187: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 00:07.218: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 00:07.312: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 00:07.328: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Preparing to Leave State. 00:07.359: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Setting Progress 100. 00:07.375: INFO: |IEAK After IEUPD >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 00:07.406: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Posting Exit Phase Message. 00:07.421: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 00:07.437: INFO: |IEAK After IEUPD >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 00:07.453: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: Actual Phase: 11 00:07.484: INFO: |IEAK After IEUPD >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 00:07.500: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: Actual Phase: 11 00:07.531: INFO: |IEAK After IEUPD >>> <[END]-------------------------------- 00:07.562: INFO: |IEAK After IEUPD >>> CPageProgress::_ChangeState: Original Phase: 11 00:07.609: INFO: |IEAK Finalize >>> <span style="color:blue"> >[bEGIN]------------------------------</span> 00:07.625: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 12 00:07.640: INFO: |IEAK Finalize >>> SKIP[FALSE]>>Looking for skip clauses 00:07.671: INFO: |IEAK Finalize >>> SKIP[FALSE]>> Adding [FALSE] Condition: !_psdStateData->GetIsInitSuccessful() 00:07.687: INFO: |IEAK Finalize >>> SKIP[FALSE]>> Adding [TRUE ] Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_NONE 00:07.703: INFO: |IEAK Finalize >>> SKIP[TRUE ]>> Adding [FALSE] Condition: g_pApp->GetState()->AreWeDoingUninstall() 00:07.734: INFO: |IEAK Finalize >>> SKIP[TRUE ]>> Adding [TRUE ] Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() 00:07.750: INFO: |IEAK Finalize >>> SKIP[TRUE ]>>Result: SKIPPING This Phase 00:07.765: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Preparing to Leave State. 00:07.796: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Setting Progress 100. 00:07.812: INFO: |IEAK Finalize >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 00:07.828: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Posting Exit Phase Message. 00:07.859: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 00:07.875: INFO: |IEAK Finalize >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 00:07.890: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 12 00:07.921: INFO: |IEAK Finalize >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 00:07.937: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 12 00:07.953: INFO: |IEAK Finalize >>> <[END]-------------------------------- 00:07.984: INFO: |IEAK Finalize >>> CPageProgress::_ChangeState: Original Phase: 12 00:08.000: INFO: |Finalize >>> <span style="color:blue"> >[bEGIN]------------------------------</span> 00:08.015: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 13 00:08.046: INFO: |Finalize >>> SKIP[FALSE]>>Looking for skip clauses 00:08.062: INFO: |Finalize >>> SKIP[FALSE]>>Result: RUNNING This Phase 00:08.078: INFO: |Finalize >>> CInstallationState::_ExitState: Preparing to Leave State. 00:08.109: INFO: |Finalize >>> CInstallationState::_ExitState: Setting Progress 100. 00:08.125: INFO: |Finalize >>> CInstallationState::_SetProgress: Post Set Progress Message Succeeded. 00:08.140: INFO: |Finalize >>> CInstallationState::_ExitState: Posting Exit Phase Message. 00:08.171: INFO: |Finalize >>> CInstallationState::_ExitState: Post Exit Phase Message Succeeded. 00:08.187: INFO: |Finalize >>> CPageProgress::DlgProc: Received WM_PR_SETPROGRESS, 64, 0 00:08.203: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 13 00:08.296: INFO: |Finalize >>> CPageProgress::DlgProc: Received WM_PR_EXITPHASE, 0, 0 00:08.328: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: Actual Phase: 13 00:08.343: INFO: |Finalize >>> <[END]-------------------------------- 00:08.359: INFO: |Finalize >>> CPageProgress::_ChangeState: Original Phase: 13 00:11.046: INFO: REBOOT: not needed. 00:11.062: INFO: REBOOT: not needed. 00:11.093: INFO: Installer return value: hr=0x00000000 00:11.125: INFO: Setup exit code: 0x00000000. Quote
Guest PA Bear [MS MVP] Posted September 11, 2009 Posted September 11, 2009 If you must make identical posts to multiple newsgroups, please cross-post one (1) message to all of them. Thank you. Multiposting vs Crossposting: http://www.blakjak.demon.co.uk/mul_crss.htm KSC wrote:<span style="color:blue"> > Dear, > > I try to install IE 8 through WSUS on Windows XP SP2 clients, but without > success, is the error in the log file the cause? ERROR: Couldn't read > value: 'LIPPackage' from [Version] section in update.inf > > > 00:00.000: > ==================================================================== > > 00:00.125: Started: 2009/09/10 (Y/M/D) 14:52:38.075 (local) > > 00:00.140: Time Format in this log: MM:ss.mmm > (minutes:seconds.milliseconds) > > 00:00.156: Command line: f:8accc5038729beaaae0194updateiesetup.exe > /wu-silent > > 00:00.187: INFO: Checking version for > f:8accc5038729beaaae0194updateiesetup.exe: 8.0.6001.18702 > > 00:00.296: INFO: Acquired Package Installer Mutex > > 00:00.312: INFO: Operating System: Windows Workstation: 5.1.2600 > (Service > Pack 2) > > 00:00.515: ERROR: Couldn't read value: 'LIPPackage' from [Version] > section > in update.inf > > 00:00.531: INFO: Checking Prerequisites > > 00:00.562: INFO: Checking version for C:WINDOWSsystem32msctf.dll: > 5.1.2600.2180 > > 00:00.578: INFO: Prerequisites Satisfied: No > > 00:00.640: INFO: Checking version for C:Program FilesInternet > Exploreriexplore.exe: 7.0.6000.16876 > > 00:00.671: INFO: C:Program FilesInternet Exploreriexplore.exe > version: > 7.0.6000.16876 > > 00:00.687: INFO: Checking if iexplore.exe's current version is between > 8.0.6001.0... > > 00:00.718: INFO: ...and 8.1.0.0... > > 00:00.734: INFO: Maximum version on which to run IEAK branding is: > 8.1.0.0... > > 00:00.750: INFO: iexplore.exe version check success. Install can > proceed. > > 00:00.781: INFO: Checking version for C:Program FilesInternet > Exploreriexplore.exe: 7.0.6000.16876 > > 00:00.796: INFO: Checking version for C:WINDOWSsystem32mshtml.dll: > 7.0.6000.16890 > > 00:00.828: INFO: Checking version for C:WINDOWSsystem32wininet.dll: > 7.0.6000.16876 > > 00:00.906: INFO: EULA not shown in passive or quiet mode. > > 00:00.937: INFO: Skip directly to Options page. > > 00:01.000: INFO: |PreInstall >>> CPageProgress::DlgProc: Exiting > Phase PH_NONE > > 00:01.015: INFO: |PreInstall >>> CPageProgress::_ChangeState: > Original Phase: 0 > > 00:01.031: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 1 > > 00:01.062: INFO: |Initialize >>><span style="color:green"> >> [bEGIN]------------------------------</span> > > 00:01.078: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 1 > > 00:01.093: INFO: |Initialize >>> SKIP[FALSE]>>Looking for skip > clauses > > 00:01.125: INFO: |Initialize >>> SKIP[FALSE]>>Result: RUNNING > This > Phase > > 00:01.140: INFO: |Initialize >>> Calculating bytes needed to > install. > > 00:01.171: INFO: |Initialize >>> Diskspace Required: 151918308 > > 00:01.187: INFO: |Initialize >>> Diskspace Available to user: > 26173431808 > > 00:01.265: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: > CoCreateInstance.CLSID_UpdateSession: HResult 0x00000000 > > 00:01.296: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: > PutClientApplicationID: HResult 0x00000000 > > 00:01.312: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: > CreateUpdateSearcher: HResult 0x00000000 > > 00:01.343: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: > CreateUpdateDownloader: HResult 0x00000000 > > 00:01.359: INFO: WindowsUpdate>>CWindowsUpdateMgr::Initialize: > CreateUpdateInstaller: HResult 0x00000000 > > 00:01.375: INFO: WindowsUpdate>>WindowsUpdateMgr::Initialize: State > Change: SS_INITIALIZED. > > 00:01.406: INFO: |Initialize >>> CStateInitialize::OnInitialize: > Windows Update Manager Initialization Result: 0x00000000 > > 00:01.421: INFO: |Initialize >>> CInstallationState::_ExitState: > Preparing to Leave State. > > 00:01.437: INFO: |Initialize >>> CInstallationState::_ExitState: > Setting Progress 100. > > 00:01.468: INFO: |Initialize >>> > CInstallationState::_SetProgress: > Post Set Progress Message Succeeded. > > 00:01.484: INFO: |Initialize >>> CInstallationState::_ExitState: > Posting Exit Phase Message. > > 00:01.500: INFO: |Initialize >>> CInstallationState::_ExitState: > Post Exit Phase Message Succeeded. > > 00:01.531: INFO: |Initialize >>> CPageProgress::DlgProc: Received > WM_PR_SETPROGRESS, 64, 0 > > 00:01.546: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 1 > > 00:01.578: INFO: |Initialize >>> CPageProgress::DlgProc: Received > WM_PR_EXITPHASE, 0, 0 > > 00:01.593: INFO: |Initialize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 1 > > 00:01.609: INFO: |Initialize >>> > <[END]-------------------------------- > > 00:01.625: INFO: |Initialize >>> CPageProgress::_ChangeState: > Original Phase: 1 > > 00:01.656: INFO: |Uninstall Prev. >>><span style="color:green"> >> [bEGIN]------------------------------</span> > > 00:01.671: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: > Actual Phase: 2 > > 00:01.687: INFO: |Uninstall Prev. >>> SKIP[FALSE]>>Looking for skip > clauses > > 00:01.718: INFO: |Uninstall Prev. >>> SKIP[FALSE]>> Adding [FALSE] > Condition: !_psdStateData->GetIsInitSuccessful() > > 00:01.734: INFO: |Uninstall Prev. >>> SKIP[FALSE]>> Adding [TRUE ] > Condition: !g_pApp->GetState()->AreWeDoingUninstall() > > 00:01.750: INFO: |Uninstall Prev. >>> SKIP[TRUE ]>>Result: SKIPPING > This > Phase > > 00:01.781: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: > Preparing to Leave State. > > 00:01.796: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: > Setting Progress 100. > > 00:01.812: INFO: |Uninstall Prev. >>> > CInstallationState::_SetProgress: > Post Set Progress Message Succeeded. > > 00:01.843: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: > Posting Exit Phase Message. > > 00:01.859: INFO: |Uninstall Prev. >>> CInstallationState::_ExitState: > Post Exit Phase Message Succeeded. > > 00:01.875: INFO: |Uninstall Prev. >>> CPageProgress::DlgProc: Received > WM_PR_SETPROGRESS, 64, 0 > > 00:01.906: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: > Actual Phase: 2 > > 00:01.921: INFO: |Uninstall Prev. >>> CPageProgress::DlgProc: Received > WM_PR_EXITPHASE, 0, 0 > > 00:01.937: INFO: |Uninstall Prev. >>> CPageProgress::_UpdateDisplay: > Actual Phase: 2 > > 00:01.968: INFO: |Uninstall Prev. >>> > <[END]-------------------------------- > > 00:01.984: INFO: |Uninstall Prev. >>> CPageProgress::_ChangeState: > Original Phase: 2 > > 00:02.000: INFO: |WU Download >>><span style="color:green"> >> [bEGIN]------------------------------</span> > > 00:06.609: INFO: |Inst. Post-Upd. >>><span style="color:green"> >> [bEGIN]------------------------------</span> > > 00:06.625: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: > Actual Phase: 10 > > 00:06.656: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>>Looking for skip > clauses > > 00:06.671: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>> Adding [FALSE] > Condition: !_psdStateData->GetIsInitSuccessful() > > 00:06.687: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>> Adding [FALSE] > Condition: !g_pApp->GetState()->GetOptShouldUpdate() > > 00:06.718: INFO: |Inst. Post-Upd. >>> SKIP[FALSE]>> Adding [TRUE ] > Condition: !g_pApp->GetState()->GetResultCouldInstallIE() > > 00:06.734: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] > Condition: > g_pApp->GetState()->GetResultPostIEUpdateState()!=WU_COULD_DOWNLOAD > > 00:06.750: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] > Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_BRANDING > > 00:06.781: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [FALSE] > Condition: g_pApp->GetState()->AreWeDoingUninstall() > > 00:06.796: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>> Adding [TRUE ] > Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() > > 00:06.812: INFO: |Inst. Post-Upd. >>> SKIP[TRUE ]>>Result: SKIPPING > This > Phase > > 00:06.843: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: > Preparing to Leave State. > > 00:06.859: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: > Setting Progress 100. > > 00:06.875: INFO: |Inst. Post-Upd. >>> > CInstallationState::_SetProgress: > Post Set Progress Message Succeeded. > > 00:06.906: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: > Posting Exit Phase Message. > > 00:06.921: INFO: |Inst. Post-Upd. >>> CInstallationState::_ExitState: > Post Exit Phase Message Succeeded. > > 00:06.937: INFO: |Inst. Post-Upd. >>> CPageProgress::DlgProc: Received > WM_PR_SETPROGRESS, 64, 0 > > 00:06.968: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: > Actual Phase: 10 > > 00:06.984: INFO: |Inst. Post-Upd. >>> CPageProgress::DlgProc: Received > WM_PR_EXITPHASE, 0, 0 > > 00:07.000: INFO: Setting Windows Update Registry Keys: > LookingForUpdates=0x00 - ForcePostUpdateDownload=0x00 - > ForcePostUpdateInstall=0x00 > > 00:07.031: INFO: |Inst. Post-Upd. >>> CPageProgress::_UpdateDisplay: > Actual Phase: 10 > > 00:07.046: INFO: |Inst. Post-Upd. >>> > <[END]-------------------------------- > > 00:07.062: INFO: |Inst. Post-Upd. >>> CPageProgress::_ChangeState: > Original Phase: 10 > > 00:07.093: INFO: |IEAK After IEUPD >>><span style="color:green"> >> [bEGIN]------------------------------</span> > > 00:07.109: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: > Actual Phase: 11 > > 00:07.125: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>>Looking for skip > clauses > > 00:07.156: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>> Adding [FALSE] > Condition: !_psdStateData->GetIsInitSuccessful() > > 00:07.171: INFO: |IEAK After IEUPD >>> SKIP[FALSE]>> Adding [TRUE ] > Condition: g_pApp->GetState()->GetOptIEAKMode()!=IEAK_PACKAGE > > 00:07.187: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>> Adding [FALSE] > Condition: g_pApp->GetState()->AreWeDoingUninstall() > > 00:07.218: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>> Adding [TRUE ] > Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() > > 00:07.312: INFO: |IEAK After IEUPD >>> SKIP[TRUE ]>>Result: SKIPPING > This > Phase > > 00:07.328: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: > Preparing to Leave State. > > 00:07.359: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: > Setting Progress 100. > > 00:07.375: INFO: |IEAK After IEUPD >>> > CInstallationState::_SetProgress: > Post Set Progress Message Succeeded. > > 00:07.406: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: > Posting Exit Phase Message. > > 00:07.421: INFO: |IEAK After IEUPD >>> CInstallationState::_ExitState: > Post Exit Phase Message Succeeded. > > 00:07.437: INFO: |IEAK After IEUPD >>> CPageProgress::DlgProc: Received > WM_PR_SETPROGRESS, 64, 0 > > 00:07.453: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: > Actual Phase: 11 > > 00:07.484: INFO: |IEAK After IEUPD >>> CPageProgress::DlgProc: Received > WM_PR_EXITPHASE, 0, 0 > > 00:07.500: INFO: |IEAK After IEUPD >>> CPageProgress::_UpdateDisplay: > Actual Phase: 11 > > 00:07.531: INFO: |IEAK After IEUPD >>> > <[END]-------------------------------- > > 00:07.562: INFO: |IEAK After IEUPD >>> CPageProgress::_ChangeState: > Original Phase: 11 > > 00:07.609: INFO: |IEAK Finalize >>><span style="color:green"> >> [bEGIN]------------------------------</span> > > 00:07.625: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 12 > > 00:07.640: INFO: |IEAK Finalize >>> SKIP[FALSE]>>Looking for skip > clauses > > 00:07.671: INFO: |IEAK Finalize >>> SKIP[FALSE]>> Adding [FALSE] > Condition: !_psdStateData->GetIsInitSuccessful() > > 00:07.687: INFO: |IEAK Finalize >>> SKIP[FALSE]>> Adding [TRUE ] > Condition: g_pApp->GetState()->GetOptIEAKMode()==IEAK_NONE > > 00:07.703: INFO: |IEAK Finalize >>> SKIP[TRUE ]>> Adding [FALSE] > Condition: g_pApp->GetState()->AreWeDoingUninstall() > > 00:07.734: INFO: |IEAK Finalize >>> SKIP[TRUE ]>> Adding [TRUE ] > Condition: !g_pApp->GetState()->GetPrerequisiteSatisfied() > > 00:07.750: INFO: |IEAK Finalize >>> SKIP[TRUE ]>>Result: SKIPPING > This > Phase > > 00:07.765: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: > Preparing to Leave State. > > 00:07.796: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: > Setting Progress 100. > > 00:07.812: INFO: |IEAK Finalize >>> > CInstallationState::_SetProgress: > Post Set Progress Message Succeeded. > > 00:07.828: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: > Posting Exit Phase Message. > > 00:07.859: INFO: |IEAK Finalize >>> CInstallationState::_ExitState: > Post Exit Phase Message Succeeded. > > 00:07.875: INFO: |IEAK Finalize >>> CPageProgress::DlgProc: Received > WM_PR_SETPROGRESS, 64, 0 > > 00:07.890: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 12 > > 00:07.921: INFO: |IEAK Finalize >>> CPageProgress::DlgProc: Received > WM_PR_EXITPHASE, 0, 0 > > 00:07.937: INFO: |IEAK Finalize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 12 > > 00:07.953: INFO: |IEAK Finalize >>> > <[END]-------------------------------- > > 00:07.984: INFO: |IEAK Finalize >>> CPageProgress::_ChangeState: > Original Phase: 12 > > 00:08.000: INFO: |Finalize >>><span style="color:green"> >> [bEGIN]------------------------------</span> > > 00:08.015: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 13 > > 00:08.046: INFO: |Finalize >>> SKIP[FALSE]>>Looking for skip > clauses > > 00:08.062: INFO: |Finalize >>> SKIP[FALSE]>>Result: RUNNING > This > Phase > > 00:08.078: INFO: |Finalize >>> CInstallationState::_ExitState: > Preparing to Leave State. > > 00:08.109: INFO: |Finalize >>> CInstallationState::_ExitState: > Setting Progress 100. > > 00:08.125: INFO: |Finalize >>> > CInstallationState::_SetProgress: > Post Set Progress Message Succeeded. > > 00:08.140: INFO: |Finalize >>> CInstallationState::_ExitState: > Posting Exit Phase Message. > > 00:08.171: INFO: |Finalize >>> CInstallationState::_ExitState: > Post Exit Phase Message Succeeded. > > 00:08.187: INFO: |Finalize >>> CPageProgress::DlgProc: Received > WM_PR_SETPROGRESS, 64, 0 > > 00:08.203: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 13 > > 00:08.296: INFO: |Finalize >>> CPageProgress::DlgProc: Received > WM_PR_EXITPHASE, 0, 0 > > 00:08.328: INFO: |Finalize >>> CPageProgress::_UpdateDisplay: > Actual Phase: 13 > > 00:08.343: INFO: |Finalize >>> > <[END]-------------------------------- > > 00:08.359: INFO: |Finalize >>> CPageProgress::_ChangeState: > Original Phase: 13 > > 00:11.046: INFO: REBOOT: not needed. > > 00:11.062: INFO: REBOOT: not needed. > > 00:11.093: INFO: Installer return value: hr=0x00000000 > > 00:11.125: INFO: Setup exit code: 0x00000000. </span> Quote
