General Question <XP vs 7>
Guest Alias
On 06/16/2010 04:12 AM, atec7 7 > wrote:
> Bill Yanaire, ESQ wrote:
>> One thing for certain is it's best to stay away from all distros of
>> Linux. Especially that Shitty Ubuntu.
> Oh look another ill informed winblows apologist
Not to mention too fucking stupid to install and run Ubuntu.
Alias
Guest Marti van Lin
Op 15-06-10 06:10, Frank wrote:
> On 6/14/2010 7:37 PM, JC wrote:
>> First allow me to apologize as I am no USENET guru. Typically when I
>> decide
>> to make a post in hopes some kind soul(s) will give some input/feedback
>> towards my interests/concerns I am clueless which group to post to. But I
>> will say I generally get a positive reponse where ever I post.
>> For the past five or so years I have used 2000 on my home machines. They
>> actually still use 98 on the clients where I work (which is medical
>> laboratory) with an antiquated Novell network o/s and Oracle DBMS on the
>> server. This is primarily due to the fact that I have very antiquated
>> tools
>> (Visual Cafe for my IDE with SDK 1.1); my app will only run on 98
>> machines.
>> Anyway, that is neither here nor there.
>> My question is about Windows XP vs 7. I am at a point where I would
>> like to
>> upgrade my home machines to XP. Even though I've been using 2000 for
>> so long
>> (and very satisfied with it) I do have some XP experience/knowledge.
>> Problem
>> is that one of the used machines I just purchased has XP on it because
>> that
>> is what was on it when I got it. Seems like it is not possible to
>> purchase
>> XP nowadays. It is all Windows 7.
>> A few friends here and there have had me come and look at their Windows 7
>> machines. They think because I have a degree in CompSci/Math that I know
>> everything there is to know about computers. I cannot make them
>> understand I
>> am a GUI programmer, database programmer, amateur DBA, and data
>> analyst. I
>> keep telling them I am not a technician but they will not believe me. The
>> handful of times I've played around with a Windows 7 machine so far I've
>> found it very counterintuitive and confusing. I do not like it at all!
>> Not
>> knowing much about XP anytime I've worked on an XP machine I've typically
>> had little if any problems.
>> So the question I guess: Is XP a thing of the past? Can I no longer
>> get XP
>> (it definitely is not in stores)? If I wanted to migrate the clients
>> to XP
>> at work would that not be possible?
>> Many Thanks,
>> -JC
> Take the plunge and go with 7, otherwise you'll be left far behind very
> quickly. 7 is the very best OS available today.
Or why not take the plunge and go with GNU/Linux? which is - in contrast
to any Microsoft Windows version - supported for all eternity.
If you migrate to ether Windows XP or 7, in time you will have the same
problem. Microsoft will quit supporting Windows 7 (XP will be killed in
2014) and forces you to buy a new version.
Beside that, migrating from Windows 98/2000 to ether Windows XP or 7 is
quite a culture shock. The GUI is totally different.
So if you're at it, why not take the plunge and move to Ubuntu for example?
It saves you and your organization lots of licensing money (because it's
gratis and fully legal) and the amount of development tools (IDE's etc.)
available for GNU/Linux, will knock you off your socks ;-)
You are still able to use Windows 98 if that is important. Simply
install Oracle VirtualBox (Desktop virtualisator) and install Windows 98
in a virtual machine.
I've done it before and it worked flawlessly. And just to think I am
only a hobbyist home user ;-)
You can have gratis support right here:
http://ubuntuusers.de/
or (if you are not German) here:
http://www.ubuntu.com/
With kind regards,
|_|0|_| Marti T. van Lin
|-|_|0| Registered GNU/Linux user 513040
|0|0|0| http://www.soundclick.com/martivanlin
"Marti van Lin" <ml2mst@gmail.com> wrote in message
news:hvacek$f97$1@news.albasani.net...
>>> decide
>>> I
>>> tools
>>> machines.
>>> like to
>>> so long
>>> Problem
>>> that
>>> purchase
>>> 7
>>> understand I
>>> analyst. I
>>> The
>>> Not
>>> typically
>>> get XP
>>> to XP
>>> Many Thanks,
>>> -JC
> example?
It is completely pointless arguing which is the 'best' operating system,
when these should be invisible to the user and never require the use
of DOS-like text-based commands to fix bugs/incompatibilities.
What the VAST majority of users do is buy applications. They do not
care about operating systems. If a professional needs to run (say) Adobe
Premiere Pro CS/5 as this is his industry's standard, then they will use an
OS on which it is designed to run. Simple as that.
Until application vendors start supplying versions which run natively
in linux etc without using emulators or virtual machines (both of which
require geek-level skills to configure and then fix the known bugs),
linux and it's like will remain the poor cousin of the likes of Windows.
Me? I use applications. As for OS's (in order of preference), I run
my apps in Windows7x64, XP and Kubuntu.
Rob
Guest Frank
>>> decide
>>> tools
>>> machines.
>>> like to
>>> so long
>>> Problem
>>> that
>>> purchase
>>> understand I
>>> analyst. I
>>> Not
>>> get XP
>>> to XP
>>> Many Thanks,
>>> -JC
> With kind regards,
Nobody is looking to downgrade, which is what you're recommending.
Guest Frank
On 6/16/2010 2:34 AM, Alias wrote:
> On 06/15/2010 10:27 PM, Bill Yanaire, ESQ wrote:
>> "Alias" <aka@maskedandanymous.org.invalido> wrote in message
>> news:hv8jah$ukh$1@news.eternal-september.org...
>>>> news:hv7ui5$8m6$1@news.eternal-september.org...
>>>>> Tim Slattery wrote:
>>>>>>> get XP
>>>>>>> to XP
>>>>>> XP is two versions ago. At this point MS is still supporting it, but
>>>>>> eventually they will drop that while Win7 support continues. You can
>>>>>> bet that support for any new hardware that comes along will be in
>>>>>> Win7, maybe in Vista, but not in XP.
>>>>>> IMHO, migrating your work machines to XP instead of Win7 at this
>>>>>> point
>>>>>> would not be a good idea.
>>>>> I don't think the hardware folks will stop making XP drivers until XP
>>>>> is not the OS on the vast majority of computers.
>>>>> Alias
>>> Ubuntu doesn't have the problem of becoming outdated like Windows 3,
>>> 95, 98, 98SE, Me, NT 3, NT 4 or XP do which was the subject at hand.
>>> Alias
>> You are right. Ubuntu doesn't have the problem of BECOMING outdated. It
>> has always been OUTDATED and therefore irrelevant to 99.9999999% of the
>> computer users who try that piece of shit OS.
> As we all know, you're too stupid to install Ubuntu and don't know what
> the fuck you're talking about. Your ever post proves this.
As we all know, you are stupid enough to install ubuntu and obviously
don't know what you're talking about.
Your every post proves that point.
Guest Frank
On 6/16/2010 1:22 AM, Parko wrote:
> On Wed, 16 Jun 2010 17:43:52 +1000, John Morrison sgraffire:
>> I tried Ubuntu on an earlier computer, it was quite a reasonable OS but
>> wouldn't run my favourite Windows programs.
> Of course it won't - natively. You could have tried Wine, or Crossover,
> or Playonlinux.
> http://www.winehq.org/about/
> http://www.codeweavers.com/products/
> http://www.playonlinux.com/en/
What a total wast of time.
Guest Leythos
In article <hvacek$f97$1@news.albasani.net>, ml2mst@gmail.com says...
That's not really true - the new versions are released, updates are
released, at some point you upgrade because they don't keep supporting
version ABC.ABC...
The reason people don't run Linux more than they already do is support
and compatibility with devices and people not running Linux.
You can't trust your best friends, your five senses, only the little
voice inside you that most civilians don't even hear -- Listen to that.
Trust yourself.
spam999free@rrohio.com (remove 999 for proper email address)
Guest Marti van Lin
> version ABC.ABC...
There for distributions provide a distribution upgrade, from the update
manager.
I kept on working while the distribution upgrade from the former Long
Term Support version to the current LTS version was in progress.
I'm sorry I didn't have any problems with hardware support for the last
five years.
If you don't have a driver disk for WinXP or 7, your screwed too. Under
GNU/Linux it's much more likely that your hardware will be supported
right out of the box.
Guest Leythos
In article <hvar1p$76s$1@news.albasani.net>, ml2mst@gmail.com says...
> > version ABC.ABC...
> manager.
> five years.
How many Epson printers do you have?
How many Cannon printers do you have?
How many All-In-One printer/scanner/fax devices do you have fully
operational with Linux?
The list goes on.
The one thing we know for sure, drivers for Windows generally come out
with the devices and certainly quicker than for Linux.
Trust yourself.
Guest Alias
Leythos wrote:
> In article<hvar1p$76s$1@news.albasani.net>, ml2mst@gmail.com says...
>>> In article<hvacek$f97$1@news.albasani.net>, ml2mst@gmail.com says...
>>> version ABC.ABC...
>> manager.
>> five years.
I have a few and they work great with Linux.
Canon is famous for not being Linux friendly but that's Canon's fault
and lose. A little hardware research will go a long way.
I have an HP All-in-One that works just fine. It doesn't have Vista or
Windows 7 drivers though.
> The list goes on.
So you're saying that Windows 7 will not have a problem with each and
every printer ever made?
Research before buying. You don't do that?
Alias
Guest Marti van Lin
>>>> decide
>>>> I
>>>> tools
>>>> machines.
>>>> like to
>>>> so long
>>>> Problem
>>>> that
>>>> purchase
>>>> 7
>>>> understand I
>>>> analyst. I
>>>> The
>>>> Not
>>>> typically
>>>> get XP
>>>> to XP
>>>> Many Thanks,
>>>> -JC
>> example?
I wasn't arguing about what the "best" Operating System is. I merely
offered the OP another money saving option.
The OP of course is free to ignore ;-)
[pointless Evangelism/Advocacy snipped]
Guest Marti van Lin
>>>> decide
>>>> But I
>>>> They
>>>> the
>>>> tools
>>>> machines.
>>>> like to
>>>> so long
>>>> Problem
>>>> that
>>>> purchase
>>>> Windows 7
>>>> know
>>>> understand I
>>>> analyst. I
>>>> me. The
>>>> I've
>>>> Not
>>>> typically
>>>> get XP
>>>> to XP
>>>> Many Thanks,
>>>> -JC
>> example?
>> With kind regards,
You are a Liar and a fraud!
I'm not interested in arguing with a religious "what ever company,
Operating System, distro" zealot :-p
plonk
Guest Alias
>>>>> decide
>>>>> But I
>>>>> They
>>>>> the
>>>>> tools
>>>>> machines.
>>>>> like to
>>>>> so long
>>>>> Problem
>>>>> that
>>>>> purchase
>>>>> Windows 7
>>>>> know
>>>>> understand I
>>>>> analyst. I
>>>>> me. The
>>>>> I've
>>>>> Not
>>>>> typically
>>>>> get XP
>>>>> to XP
>>>>> Many Thanks,
>>>>> -JC
>>> example?
>>> With kind regards,
He's actually much worse.
> plonk
And yet another person plonks Frank the Wank.
Alias
Guest Frank
>>>>> decide
>>>>> But I
>>>>> They
>>>>> the
>>>>> tools
>>>>> machines.
>>>>> like to
>>>>> so long
>>>>> Problem
>>>>> that
>>>>> purchase
>>>>> Windows 7
>>>>> know
>>>>> understand I
>>>>> analyst. I
>>>>> me. The
>>>>> I've
>>>>> Not
>>>>> typically
>>>>> get XP
>>>>> to XP
>>>>> Many Thanks,
>>>>> -JC
>>> example?
>>> With kind regards,
Now you're projecting.
Then take your own advice and stop doing it.
IOW's, STFU!
> plonk
hehehe...got your panties all in a bunch linturd?
Guest Frank
>>>>>> decide
>>>>>> input/feedback
>>>>>> But I
>>>>>> They
>>>>>> the
>>>>>> tools
>>>>>> machines.
>>>>>> like to
>>>>>> so long
>>>>>> Problem
>>>>>> because
>>>>>> that
>>>>>> purchase
>>>>>> Windows 7
>>>>>> know
>>>>>> understand I
>>>>>> analyst. I
>>>>>> me. The
>>>>>> I've
>>>>>> all!
>>>>>> Not
>>>>>> typically
>>>>>> get XP
>>>>>> to XP
>>>>>> Many Thanks,
>>>>>> -JC
>>>>> very
>>>> contrast
>>>> example?
>>>> it's
>>>> etc.)
>>>> Windows 98
>>>> With kind regards,
You two linturds need to get a room.
>> plonk
Another linturd nobody (except you) gives a shit about.
Guest Frank
>> version ABC.ABC...
> manager.
> five years.
Now you're a GD LIAR, which is typical of you linutrd asshole losers.
Just like alias, the sheep-fucking lying linturd POS loser asshole creep.
Guest Frank
alias lies again!
>>>>> contrast
>>>> version ABC.ABC...
>>> manager.
>>> five years.
LIAR! No you don't. You only have ( according to you) one HP printer.
LIAR!
More of your lies?
Figures!
STFU LIAR!
>> The list goes on.
Still making up things others never said.
Figures, What a cock sucking POS LIAR you are.
Get lost creep.
Fact it asshole, the world runs on Windows, so most all hardware today
has drivers for Windows OS's.
Live with it loser.
Guest Leythos
alias lies again!
In article <4c19085b@news.x-privat.org>, fb@sr2.cmm says...
> >>>>> contrast
> >>>> version ABC.ABC...
> >>> manager.
> >>> five years.
> LIAR!
> More of your lies?
> Figures!
> STFU LIAR!
> >> The list goes on.
> Get lost creep.
> Live with it loser.
I have Alias kill filed, but it's obvious to anyone that's actually used
Linux that he's lying, they have crappy printer support and a lot of the
supported printers have basic controls and not the feature rich controls
or options that are included with most Windows printer drivers.
My video card, on one of my laptops, does not have a direct Windows 7
driver, but, something Alias would not know, is that the XP driver works
perfectly and at all the same resolutions. On a Linux distro I can only
get 1024x768, and since the laptop is a wide screen, the fonts are
skewed.
I can remember Alias bashing vist, claiming direct problems experience,
and then he slipped up and admitted he had never installed Vista or even
used it himself...
Trust yourself.
Guest Alias
alias lies again!
Leythos wrote:
> In article<4c19085b@news.x-privat.org>, fb@sr2.cmm says...
>>>>>>> contrast
>>>>>> version ABC.ABC...
>>>>> manager.
>>>>> five years.
>> LIAR!
>> More of your lies?
>> Figures!
>> STFU LIAR!
>>>> The list goes on.
>> Get lost creep.
>> Live with it loser.
You obviously haven't installed the latest Ubuntu but that won't stop
you from lying about it.
> skewed.
Not Ubuntu. Probably one of the distros you say are "better".
> used it himself...
Got any more lies you can't substantiate? I find it interesting that you
have me kill filed but don't have Frank kill filed. I guess your
priorities are about as skewered as your version of the truth.
Alias
Guest Bill Yanaire, ESQ
"Alias" <aka@hewhoismasked&anonymous.com> wrote in message
news:hva5s3$8op$6@news.eternal-september.org...
> Alias
There you go lying again. I have installed that INFERIOR Ubuntu and
realized that Ubuntu doesn't run the programs I need. Therefore Ubuntu is
worthless. Oops.
news:hva5t6$8op$7@news.eternal-september.org...
> Alias
I am smart enough to know SHIT when I see it. Ubuntu is just that: SHIT!
Oops.
Guest Alias
>> what the fuck you're talking about. Your ever post proves this.
>> Alias
No you haven't.
Alias
Guest Alias
>> Alias
No, you're not.
No it isn't.
> Oops.
You are an oops, I agree.
Alias
Guest Neil Harrington
"Sj" <Sj@NOTforMAIL.not> wrote in message
news:ifbf16ho5msvnj6vgb64qionouchvcs59o@4ax.com...
> On Mon, 14 Jun 2010 21:37:22 -0500, "JC" <jjcardella@hotmail.com>
>>decide
>>tools
>>machines.
>>My question is about Windows XP vs 7. I am at a point where I would like
>>to
>>upgrade my home machines to XP. Even though I've been using 2000 for so
>>long
>>Problem
>>that
>>is what was on it when I got it. Seems like it is not possible to purchase
>>everything there is to know about computers. I cannot make them understand
>>I
>>am a GUI programmer, database programmer, amateur DBA, and data analyst. I
>>found it very counterintuitive and confusing. I do not like it at all! Not
>>So the question I guess: Is XP a thing of the past? Can I no longer get XP
>>(it definitely is not in stores)? If I wanted to migrate the clients to XP
>>Many Thanks,
>>-JC
> Here I thought I was the very last 2000 user on the planet!
No, I'll bet there are still a lot of us using Win2000.
> Can't help you w/ your question but will follow all the replies, as I
> have access to an unused, relatively new 64 bit/Win 7 computer.
> My thoughts were to format the HD & install XP. Is that doable
> on a 64 bit machine? And I didn't know Win 7 has an XP mode.
> I'm completely satisfied w/ my 2000 system & will stay w/ it till it
> quits on me. [ . . . ]
I have two Win2000 systems and I believe they are the only computers that
have never given me any trouble of any kind. I've got three WinXP systems
also (four if you count a little Samsung netbook), and I like XP very much,
but its only real advantage over 2000 as far as I'm concerned is that
nowadays it has significantly more support for both hardware and software.
news:hvb8ao$tcg$1@news.eternal-september.org...
>>> Alias
> No you haven't.
> Alias
You haven't got the money to purchase a legitimate copy of Windows 7.
