Guest BarbaraKambourelis Posted January 28, 2012 Posted January 28, 2012 HP Laptop running XP OS started running slow and strange in the last couple of days. SE had been running and did a quick scan/no problems found. Today I ran a full scan with SE and it found 3items/ trojans which I had SE remove. SE then prompted for a reboot which I did. During the reboot, it requested a scan disk and found/fixed lots of disk errors. When it was complete, all keys/touchpad are no longer activated. I tried logging into safemode but get stuck b/c there is the Ctrl-Alt-Delete (keys not recognized). Even the ctl-alt-Detete button under the panel is not working. I have added a wireless mouse so have mouse capabilities but can't get past the CTRl-AlT-Delete to begin. After doing a search, I have also tried removing the battery but that didn't work, In safe mode, I have tried rebooting from last good configuration, but that too didn't work. Please Advise. Continue reading... Quote
