DISM problem with adding updates to my WIM
Guest DrewMilizia
I am having some issues using the DISM tool to add updates to my base WIM. I have Googled to no avail..This has all been done from an elevated command prompt. I am also logged in as a domain admin so there shouldn't be any issues with permissions on the machine itself. I have also tried this with another admin account and tried both accounts on another PC to verify it wasn't a PC/Account problem. Here is the CMD line error:
C:\>dism /Image:C:\Mount /Add-Package /PackagePath:c:\Updates\KB2530548\KB2530548.msu
Deployment Image Servicing and Management tool
Version: 6.1.7600.16385
Image Version: 6.1.7600.16385
Processing 1 of 1 - Adding package c:\Updates\KB2530548\KB2530548.msu
[===========================65.9%====== ]
c:\Updates\KB2530548\KB2530548.msu: An error occurred applying the Unattend.xml
file from the .msu package.
For more information, review the log file.
Error: 0x80070005
Error: 5
Access is denied.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
Here is the part of the log file that I think the problem might be stemming from..
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SOFTWARE
2012-03-02 09:30:24, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SOFTWARE, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SYSTEM
2012-03-02 09:30:24, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SYSTEM, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SECURITY
2012-03-02 09:30:24, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SECURITY, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SAM
2012-03-02 09:30:24, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/SAM, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/COMPONENTS
2012-03-02 09:30:24, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/COMPONENTS, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/DEFAULT
2012-03-02 09:30:24, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/System32/config/DEFAULT, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Users/default/ntuser.dat
2012-03-02 09:30:24, Info CBS Failed to unload offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Users/default/ntuser.dat, the client may still need it open. [hrESULT = 0x80070005 - E_ACCESSDENIED]
2012-03-02 09:30:24, Info CBS Unloading offline registry hive: {bf1a281b-ad7b-4476-ac95-f47682990ce7}C:/Mount/Windows/system32/smi/store/Machine/schema.dat
Any help would be most appreciated.
Thanks
