my pc is hanging Setup is applying system settings
Guest Mensy
hi all im hoping someone can help, it all started a couple of days ago. i was browsing the internet when i get loads of system errors popping up which to me looked like malware, they went across the bottom of the screen and then my system shut down. upon starting up again i got update data to dmi! so i reset my bios and stuff and then all i got was a blinking white cursor i could boot into anything no safe mood. so i got ubuntu live cd to use to get all my data and that worked a treat. now I've reformatted back to factory setting with the discs my pc came with and when it says finished installation please click ok to reset it starts booting up and finishes the last part of installation and then says. "setup is applying system settings" and just hangs at that screen nothing happens. please can someone help thanx
