Guest PogMaThoin Posted March 18, 2012 Posted March 18, 2012 Hi I tried to play this game I used to play called maplestory it worked B4 on my computer and I installed it. When I went to play it gave me an (unspecified error) and I was told to run Dxdiag. I don't know how to fix this so here is the log...Please Help Me ------------------ System Information ------------------ Time of this report: 3/17/2012, 14:47:18 Machine name: ACER-6E40E97492 Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.111025-1629) Language: English (Regional Setting: English) System Manufacturer: Acer System Model: AOA150 BIOS: InsydeH2O Version v0.3305 Processor: Intel® Atom CPU N270 @ 1.60GHz (2 CPUs) Memory: 1012MB RAM Page File: 361MB used, 2066MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.2600.5512 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: Several files (kstvtune.ax, ksxbar.ax, kswdmcap.ax, etc.) are incorrectly installed in the Windows folder and should be deleted. Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: Mobile Intel® 945 Express Chipset Family Manufacturer: Intel Corporation Chip type: Intel® GMA 950 DAC type: Internal Device Key: Enum\PCI\VEN_8086&DEV_27AE&SUBSYS_015B1025&REV_03 Display Memory: n/a Current Mode: 1024 x 600 (32 bit) (60Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: igxprd32.dll Driver Version: 6.14.0010.4926 (English) DDI Version: unknown Driver Attributes: Final Retail Driver Date/Size: 2/15/2008 08:12:06, 57344 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: igxpmp32.sys Mini VDD Date: 2/15/2008 08:12:06, 5854752 bytes Device Identifier: {D7B78E66-64EE-11CF-AB60-5121A2C2CB35} Vendor ID: 0x8086 Device ID: 0x27AE SubSys ID: 0x015B1025 Revision ID: 0x0003 Revision ID: 0x0003 Video Accel: Deinterlace Caps: n/a Registry: OK DDraw Status: Not Available D3D Status: Not Available AGP Status: Not Available DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: Realtek HD Audio output Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0268&SUBSYS_1025015B&REV_1001 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: RtkHDAud.sys Driver Version: 5.10.0000.5628 (English) Driver Attributes: Final Retail WHQL Logo'd: Yes Date and Size: 5/20/2008 02:53:00, 4800000 bytes Other Files: Driver Provider: Realtek Semiconductor Corp. HW Accel Level: Full Cap Flags: 0xF5F Min/Max Sample Rate: 8000, 192000 Static/Strm HW Mix Bufs: 33, 32 Static/Strm HW 3D Bufs: 33, 32 HW Memory: 0 Voice Management: No EAX 2.0 Listen/Src: Yes, Yes I3DL2 Listen/Src: Yes, Yes Sensaura ZoomFX: No Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: Realtek HD Audio Input Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: RtkHDAud.sys Driver Version: 5.10.0000.5628 (English) Driver Attributes: Final Retail Date and Size: 5/20/2008 02:53:00, 4800000 bytes Cap Flags: 0x41 Format Flags: 0xCC0 ----------- DirectMusic ----------- DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Poll w/ Interrupt: No Registry: OK ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x8086, 0x27CA | Matching Device ID: usb\root_hub | Service: usbhub | Driver: usbhub.sys, 4/14/2008 00:15:38, 59520 bytes | Driver: usbd.sys, 4/14/2008 20:00:00, 4736 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard | Matching Device ID: pnp0303 | Upper Filters: DKbFltr | Service: i8042prt | Driver: DKbFltr.SYS, 12/7/2004 23:10:00, 16896 bytes | Driver: FILTRCOI.DLL, 12/8/2004 21:04:40, 5120 bytes | + Terminal Server Keyboard Driver | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes | Driver: kbdclass.sys, 4/14/2008 20:00:00, 24576 bytes | + Synaptics PS/2 Port Pointing Device | Matching Device ID: pnp0f13 | Upper Filters: SynTP | Service: i8042prt | Driver: i8042prt.sys, 4/14/2008 20:00:00, 52480 bytes | Driver: mouclass.sys, 4/14/2008 00:09:48, 23040 bytes | Driver: SynTP.sys, 4/24/2008 18:17:10, 225024 bytes | Driver: SynTPAPI.dll, 4/24/2008 18:31:12, 151552 bytes | Driver: SynCOM.dll, 4/24/2008 18:19:00, 163840 bytes | Driver: SynCtrl.dll, 4/24/2008 18:19:46, 200704 bytes | Driver: SynTPRes.dll, 4/24/2008 18:38:46, 5824512 bytes | Driver: SynTPCpl.dll, 4/24/2008 18:34:42, 946176 bytes | Driver: SynCntxt.rtf, 4/24/2008 18:39:12, 4659147 bytes | Driver: SynZMetr.exe, 4/24/2008 18:21:42, 241664 bytes | Driver: SynMood.exe, 4/24/2008 18:20:52, 233472 bytes | Driver: SynTPEnh.exe, 4/24/2008 18:32:08, 1044480 bytes | Driver: SynTPCOM.dll, 4/24/2008 18:31:34, 102400 bytes | Driver: Tutorial.exe, 4/24/2008 18:39:04, 327680 bytes | Driver: InstNT.exe, 4/24/2008 19:08:08, 118784 bytes | Driver: SynISDLL.dll, 4/24/2008 18:39:28, 630784 bytes | Driver: SynUnst.ini, 5/1/2008 18:40:08, 440935 bytes | Driver: fx04.wav, 5/8/2007 18:48:26, 16898 bytes | Driver: SynAcer.exe, 4/24/2008 18:22:12, 139264 bytes | Driver: SynAcerCpl.cpl, 4/24/2008 18:21:58, 241664 bytes | Driver: SynTPCo4.dll, 4/24/2008 19:07:56, 110592 bytes | + Terminal Server Mouse Driver | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD | Driver: termdd.sys, 4/14/2008 05:43:22, 40840 bytes | Driver: mouclass.sys, 4/14/2008 00:09:48, 23040 bytes ---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512) DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512) DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK ------------------- DirectPlay Adapters ------------------- DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 - ----------------------- DirectPlay Voice Codecs ----------------------- Voxware VR12 1.4kbit/s Voxware SC06 6.4kbit/s Voxware SC03 3.2kbit/s MS-PCM 64 kbit/s MS-ADPCM 32.8 kbit/s Microsoft GSM 6.10 13 kbit/s TrueSpeech 8.6 kbit/s ------------------------- DirectPlay Lobbyable Apps ------------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 115.5 GB Total Space: 147.6 GB File System: NTFS Model: WDC WD1600BEVT-22ZCT0 -------------- System Devices -------------- Name: Intel® 82801G (ICH7 Family) SMBus Controller - 27DA Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_015B1025&REV_02\3&B1BFB68&0&FB Driver: n/a Name: Microsoft UAA Bus Driver for High Definition Audio Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_015B1025&REV_02\3&B1BFB68&0&D8 Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/14/2008 20:00:00, 144384 bytes Name: Intel® 82801G (ICH7 Family) PCI Express Root Port - 27D6 Device ID: PCI\VEN_8086&DEV_27D6&SUBSYS_00000000&REV_02\3&B1BFB68&0&E3 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 68224 bytes Name: Intel® 82801G (ICH7 Family) PCI Express Root Port - 27D4 Device ID: PCI\VEN_8086&DEV_27D4&SUBSYS_00000000&REV_02\3&B1BFB68&0&E2 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 68224 bytes Name: Intel® 82801G (ICH7 Family) PCI Express Root Port - 27D2 Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_00000000&REV_02\3&B1BFB68&0&E1 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 68224 bytes Name: Intel® 82801G (ICH7 Family) PCI Express Root Port - 27D0 Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_02\3&B1BFB68&0&E0 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 68224 bytes Name: Intel® 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_015B1025&REV_02\3&B1BFB68&0&EF Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 30208 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 7168 bytes Name: Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27CB Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_015B1025&REV_02\3&B1BFB68&0&EB Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 20608 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes Name: Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27CA Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_015B1025&REV_02\3&B1BFB68&0&EA Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 20608 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes Name: Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27C9 Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_015B1025&REV_02\3&B1BFB68&0&E9 Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 20608 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes Name: Intel® 82801G (ICH7 Family) USB Universal Host Controller - 27C8 Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_015B1025&REV_02\3&B1BFB68&0&E8 Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:36, 20608 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 143872 bytes Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 05:42:10, 74240 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 00:15:38, 59520 bytes Name: Intel® 82801GBM/GHM (ICH7-M Family) Serial ATA Storage Controller - 27C4 Device ID: PCI\VEN_8086&DEV_27C4&SUBSYS_015B1025&REV_02\3&B1BFB68&0&FA Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 4/14/2008 20:00:00, 3328 bytes Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 24960 bytes Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 96512 bytes Name: Intel® 82801GBM (ICH7-M/U) LPC Interface Controller - 27B9 Device ID: PCI\VEN_8086&DEV_27B9&SUBSYS_00000000&REV_02\3&B1BFB68&0&F8 Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 37248 bytes Name: Mobile Intel® 945 Express Chipset Family Device ID: PCI\VEN_8086&DEV_27AE&SUBSYS_015B1025&REV_03\3&B1BFB68&0&10 Driver: C:\WINDOWS\system32\DRIVERS\igxpmp32.sys, 6.14.0010.4926 (English), 2/15/2008 08:12:06, 5854752 bytes Driver: C:\WINDOWS\system32\igxprd32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:06, 57344 bytes Driver: C:\WINDOWS\system32\igxpgd32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:06, 151040 bytes Driver: C:\WINDOWS\system32\igxpdv32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:16, 1670144 bytes Driver: C:\WINDOWS\system32\igxpdx32.dll, 6.14.0010.4926 (English), 2/15/2008 08:12:14, 2643968 bytes Driver: C:\WINDOWS\system32\igxpxk32.vp, 2/15/2008 07:38:38, 2096 bytes Driver: C:\WINDOWS\system32\igxpxs32.vp, 2/15/2008 10:09:18, 27024 bytes Driver: C:\WINDOWS\system32\hccutils.dll, 6.14.0010.4926 (English), 2/15/2008 07:45:44, 102400 bytes Driver: C:\WINDOWS\system32\igfxsrvc.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:08, 48128 bytes Driver: C:\WINDOWS\system32\igfxsrvc.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:16, 256536 bytes Driver: C:\WINDOWS\system32\igfxpph.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:26, 204800 bytes Driver: C:\WINDOWS\system32\igfxcpl.cpl, 6.14.0010.4926 (English), 2/15/2008 07:46:28, 122880 bytes Driver: C:\WINDOWS\system32\igfxcfg.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:06, 530968 bytes Driver: C:\WINDOWS\system32\igfxdev.dll, 6.14.0010.4926 (English), 2/15/2008 07:45:40, 208896 bytes Driver: C:\WINDOWS\system32\igfxdo.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:16, 135168 bytes Driver: C:\WINDOWS\system32\igfxtray.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:20, 141848 bytes Driver: C:\WINDOWS\system32\igfxzoom.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:24, 170520 bytes Driver: C:\WINDOWS\system32\hkcmd.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:04, 166424 bytes Driver: C:\WINDOWS\system32\igfxress.dll, 6.14.0010.4926 (English), 2/15/2008 07:45:28, 3293184 bytes Driver: C:\WINDOWS\system32\igfxpers.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:14, 137752 bytes Driver: C:\WINDOWS\system32\igfxrara.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:24, 159744 bytes Driver: C:\WINDOWS\system32\igfxrchs.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:24, 110592 bytes Driver: C:\WINDOWS\system32\igfxrcht.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:24, 110592 bytes Driver: C:\WINDOWS\system32\igfxrdan.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:26, 172032 bytes Driver: C:\WINDOWS\system32\igfxrdeu.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:26, 192512 bytes Driver: C:\WINDOWS\system32\igfxrenu.lrc, 6.14.0010.4926 (English), 2/15/2008 07:45:40, 172032 bytes Driver: C:\WINDOWS\system32\igfxresp.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 188416 bytes Driver: C:\WINDOWS\system32\igfxrfin.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 176128 bytes Driver: C:\WINDOWS\system32\igfxrfra.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 184320 bytes Driver: C:\WINDOWS\system32\igfxrheb.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 155648 bytes Driver: C:\WINDOWS\system32\igfxrita.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:30, 188416 bytes Driver: C:\WINDOWS\system32\igfxrjpn.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:30, 131072 bytes Driver: C:\WINDOWS\system32\igfxrkor.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 126976 bytes Driver: C:\WINDOWS\system32\igfxrnld.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 188416 bytes Driver: C:\WINDOWS\system32\igfxrnor.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 176128 bytes Driver: C:\WINDOWS\system32\igfxrplk.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 180224 bytes Driver: C:\WINDOWS\system32\igfxrptb.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 180224 bytes Driver: C:\WINDOWS\system32\igfxrptg.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:32, 180224 bytes Driver: C:\WINDOWS\system32\igfxrrus.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 180224 bytes Driver: C:\WINDOWS\system32\igfxrsky.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 176128 bytes Driver: C:\WINDOWS\system32\igfxrslv.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 172032 bytes Driver: C:\WINDOWS\system32\igfxrsve.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 172032 bytes Driver: C:\WINDOWS\system32\igfxrtha.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 163840 bytes Driver: C:\WINDOWS\system32\igfxrcsy.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:26, 176128 bytes Driver: C:\WINDOWS\system32\igfxrell.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:28, 192512 bytes Driver: C:\WINDOWS\system32\igfxrhun.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:30, 180224 bytes Driver: C:\WINDOWS\system32\igfxrtrk.lrc, 6.14.0010.4926 (English), 2/15/2008 07:49:34, 172032 bytes Driver: C:\WINDOWS\system32\igfxext.exe, 6.14.0010.4926 (English), 2/28/2008 10:00:10, 170520 bytes Driver: C:\WINDOWS\system32\igfxexps.dll, 6.14.0010.4926 (English), 2/15/2008 07:46:18, 24576 bytes Driver: C:\WINDOWS\system32\iglicd32.dll, 6.14.0010.4926 (English), 2/15/2008 08:00:58, 2334720 bytes Driver: C:\WINDOWS\system32\igldev32.dll, 6.14.0010.4926 (English), 2/15/2008 08:01:04, 294912 bytes Driver: C:\WINDOWS\system32\igfxCoIn_v4926.dll, 2/15/2008 08:21:56, 147456 bytes Name: Mobile Intel® 945GME Express Processor to DRAM Controller - 27AC Device ID: PCI\VEN_8086&DEV_27AC&SUBSYS_00000000&REV_03\3&B1BFB68&0&00 Driver: n/a Name: Mobile Intel® 945 Express Chipset Family Device ID: PCI\VEN_8086&DEV_27A6&SUBSYS_015B1025&REV_03\3&B1BFB68&0&11 Driver: n/a Name: Intel® 82801 PCI Bridge - 2448 Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_00000000&REV_E2\3&B1BFB68&0&F0 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 20:00:00, 68224 bytes Name: Atheros AR5007EG Wireless Network Adapter Device ID: PCI\VEN_168C&DEV_001C&SUBSYS_E008105B&REV_01\4&2803E7C1&0&00E2 Driver: n/a Name: Realtek RTL8102E Family PCI-E Fast Ethernet NIC Device ID: PCI\VEN_10EC&DEV_8136&SUBSYS_015B1025&REV_02\4&20975680&0&00E1 Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.732.0629.2009 (English), 6/29/2009 12:59:14, 142592 bytes Driver: C:\WINDOWS\system32\RtNicProp32.dll, 1.02.0000.0003 (English), 6/10/2009 03:34:20, 73728 bytes ------------------ DirectX Components ------------------ ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 279552 bytes ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 27136 bytes dxapi.sys: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 10496 bytes d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1179648 bytes d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 8192 bytes d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1689088 bytes d3dim.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 436224 bytes d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 824320 bytes d3dramp.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 590336 bytes d3drm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 350208 bytes d3dxof.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 47616 bytes d3dpmesh.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 34816 bytes dplay.dll: 5.00.2134.0001 English Final Retail 4/14/2008 20:00:00 33040 bytes dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 229888 bytes dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 23552 bytes dpwsock.dll: 5.00.2134.0001 English Final Retail 4/14/2008 20:00:00 42768 bytes dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 57344 bytes dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 29696 bytes dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 17920 bytes dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 375296 bytes dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 3072 bytes dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 3072 bytes dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 212480 bytes dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 83456 bytes dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 116736 bytes dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 21504 bytes dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 35328 bytes dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 60928 bytes dpserial.dll: 5.00.2134.0001 English Final Retail 4/14/2008 20:00:00 53520 bytes dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 158720 bytes dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 181760 bytes dimap.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 44032 bytes diactfrm.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 394240 bytes joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 68608 bytes gcdef.dll: 5.01.2600.0000 English Final Retail 4/14/2008 20:00:00 76800 bytes pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 35328 bytes dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 367616 bytes dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1293824 bytes dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 19456 bytes dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 181248 bytes dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 71680 bytes dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 104448 bytes dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 28672 bytes dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 61440 bytes dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 181248 bytes dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 35840 bytes dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 105984 bytes dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 103424 bytes dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 82432 bytes system.dll: 1.01.4322.2494 English Final Retail 1/18/2012 04:12:43 1232896 bytes Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 3/13/2012 12:23:37 473600 bytes Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 3/13/2012 12:23:31 2676224 bytes Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 3/13/2012 12:23:32 2846720 bytes Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 3/13/2012 12:23:32 563712 bytes Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 3/13/2012 12:23:33 567296 bytes Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 3/13/2012 12:23:33 576000 bytes Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 3/13/2012 12:23:34 577024 bytes Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 3/13/2012 12:23:34 577536 bytes Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 3/13/2012 12:23:35 577536 bytes Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 3/13/2012 12:23:36 578560 bytes Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 3/13/2012 12:23:38 578560 bytes Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:38 145920 bytes Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:38 159232 bytes Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:39 364544 bytes Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:39 178176 bytes Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:37 53248 bytes Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:37 12800 bytes Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 3/13/2012 12:23:36 223232 bytes dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 619008 bytes dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 1227264 bytes dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 2113536 bytes mfc40.dll: 4.01.0000.6151 English Beta Retail 9/17/2010 23:53:25 954368 bytes mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 06:33:55 978944 bytes wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 20:00:00 22528 bytes amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 70656 bytes devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 59904 bytes dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 20:00:00 498742 bytes mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 35328 bytes mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 148992 bytes msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 14336 bytes encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 20480 bytes qasf.dll: 11.00.5721.5262 English Final Retail 1/30/2009 21:34:02 211456 bytes qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 192512 bytes qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 279040 bytes qdvd.dll: 6.05.2600.6169 English Final Retail 11/3/2011 08:28:36 386048 bytes qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 562176 bytes qedwipes.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 733696 bytes quartz.dll: 6.05.2600.6169 English Final Retail 11/3/2011 08:28:36 1292288 bytes strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 01:00:21 247326 bytes iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 20:00:00 199680 bytes ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 20:00:00 848384 bytes ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 20:00:00 120320 bytes ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 20:00:00 338432 bytes ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 20:00:00 755200 bytes ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 20:00:00 200192 bytes ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 20:00:00 183808 bytes ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 20:00:00 154624 bytes mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 02:01:48 204800 bytes ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:46:38 141056 bytes ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:44 129536 bytes ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes mspclock.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:52 5376 bytes mspqm.sys: 5.01.2600.5512 English Final Retail 4/14/2008 00:09:52 4992 bytes mskssrv.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 7552 bytes swenum.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:09:54 4352 bytes mstee.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:09:52 5504 bytes ipsink.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:44 16384 bytes mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 118272 bytes ndisip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 10880 bytes streamip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 15232 bytes msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 20:00:00 1428992 bytes slip.sys: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 11136 bytes nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 85248 bytes ccdecode.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:24 17024 bytes vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 30208 bytes msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 10:11:44 17920 bytes wstcodec.sys: 5.03.2600.5512 English Final Retail 4/14/2008 01:16:26 19200 bytes wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 20:00:00 50688 bytes ------------------ DirectShow Filters ------------------ WDM Streaming VBI Codecs: NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512 CC Decoder,0x00200000,2,1,,5.03.2600.5512 WST Codec,0x00200000,1,1,,5.03.2600.5512 DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,, WMAPro over S/PDIF DMO,0x00600800,1,1,, WMA Voice Decoder DMO,0x00600800,1,1,, Mpeg4s Decoder DMO,0x00800001,1,1,, WMV Screen decoder DMO,0x00800001,1,1,, WMVideo Decoder DMO,0x00800001,1,1,, Mpeg43 Decoder DMO,0x00800001,1,1,, Mpeg4 Decoder DMO,0x00800001,1,1,, WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000 InterVideo Video Decoder,0x00700000,2,4,IVIVIDEO.ax,5.00.0011.1255 Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6169 WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416 Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416 WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416 WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416 WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416 WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8117.0416 WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8117.0416 InterVideo Audio Processor,0x00200000,1,1,IviAudioProcess.ax, DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512 Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6169 WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5262 Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5262 AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6169 WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6169 Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055 Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487 AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512 Intervideo CDSF Filter,0x00200000,0,1,ivicdsf.ax,9.00.0000.0000 WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.6076 WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169 Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055 WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000 Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487 MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6169 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169 MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512 ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6169 File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5262 WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000 DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512 Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.6169 Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000 WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5262 NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6169 Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5262 Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6169 Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.6076 Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169 Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6169 WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512 Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6169 File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8117.0416 WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5262 InterVideo Audio Decoder,0x00700000,1,1,iviaudio.ax,5.00.0011.1255 WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512 Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504 File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512 WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000 DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169 Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169 AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6169 .RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5262 InterVideo Navigator,0x00190000,0,3,Ivinav.ax,5.00.0011.1255 WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512 DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512 Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053 Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5262 ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5262 9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000 Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512 Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512 WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000 WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.6076 Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512 Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169 AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169 Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6169 QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6169 Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169 MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169 Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6169 File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6169 XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5262 AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512 Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6169 File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6169 File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6169 WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000 Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512 QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6169 MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6169 Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003 Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003 WDM Streaming Tee/Splitter Devices: Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512 WDM Streaming Data Transforms: Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,, Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512 Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512 Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512 Video Compressors: WMVideo8 Encoder DMO,0x00600800,1,1,, MSScreen encoder DMO,0x00600800,1,1,, WMVideo9 Encoder DMO,0x00600800,1,1,, MSScreen 9 encoder DMO,0x00600800,1,1,, DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512 Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055 MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6169 Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512 Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512 Intel Indeo® Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512 Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512 Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512 Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512 Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512 Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512 Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512 Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512 VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.05.2600.5512 VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.05.2600.5512 Audio Compressors: WMA Voice Encoder DMO,0x00600800,1,1,, WM Speech Encoder DMO,0x00600800,1,1,, WMAudio Encoder DMO,0x00600800,1,1,, IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6169 IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169 PCM,0x00200000,1,1,quartz.dll,6.05.2600.6169 Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6169 ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6169 DSP Group TrueSpeech,0x00200000,1,1,quartz.dll,6.05.2600.6169 Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6169 Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6169 GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6169 Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.6169 Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6169 CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169 CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6169 MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6169 Audio Capture Sources: Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.5512 Midi Renderers: Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6169 Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6169 WDM Streaming Capture Devices: Realtek HD Audio Input,0x00200000,1,1,,5.03.2600.5512 Acer Crystal Eye webcam,0x00200000,0,1,,5.03.2600.5512 WDM Streaming Rendering Devices: Realtek HD Audio output,0x00200000,1,1,,5.03.2600.5512 BDA Rendering Filters: BDA IP Sink,0x00200000,1,1,,5.03.2600.5512 Video Capture Sources: Acer Crystal Eye webcam,0x00200000,0,1,,5.03.2600.5512 WDM Streaming Mixer Devices: Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,, BDA CP/CA Filters: Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.6161 Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.6161 XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.6161 WDM Streaming Communication Transforms: Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512 Audio Renderers: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169 Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6169 Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6169 DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.6169 WDM Streaming System Devices: Realtek HD Audio Input,0x00200000,2,1,,5.03.2600.5512 Realtek HD Audio output,0x00200000,4,1,,5.03.2600.5512 BDA Receiver Component: BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512 Continue reading... Quote
