Guest TheOman Posted March 27, 2012 Posted March 27, 2012 Just quickly, this doesn't have any relation to the listed topics, and is related to system performance. Over the past week, I have noticed that MSE has not automatically started, and notifies me that I should manually restart the service; when I do this it takes a few minutes to respond, and will usually return to normal. Yesterday however, I did the same several times, with no apparent response; after a few minutes each time, it would respond with an error message which I did not record, but more or less 'MSE was unable to start'. After these few attempts, I re-installed MSE, and there have been no apparent problems with starting the service since. What is problematic however, is that during this time yesterday; my PC was running noticeably slower, with even the mouse lagging behind every few minutes. After I uninstalled MSE, I noticed that this issue did not recur; however after installing again the problem returned, because MSE was running a scan by default after installing, I assumed this was the cause. Today, my PC still has the same issues described above, that were present yesterday, before and after re-installing MSE. I have spend some time reviewing similar cases, and have attempted suggestions such as removing the C:\windows\system32\dwm.exe process from the scanning range of MSE, as suggested here http://answers.microsoft.com/en-us/protect/forum/protect_scanning/msmpengexe-running-at-95-cpu-usage/4b079063-e93a-4e80-935b-c1d7ee02a672. This did have an apparent effect for a few minutes, however the problem persisted after another five minutes or so. I am currently running Windows 7 Home Premiun 64 bit, SP1, with Intel Core i7 1.73GHz and 8Gb RAM. I know that other issues suggested such as anti-virus conflict do not exist, as my hard drive was recently reformatted after a system failure, which I believe was related to software conflicts, or system corruption; and I do not believe that these issues are related as I have experienced no similar problems. I am currently considering de-activating the real-time protection, and have limited it to incoming processes for the moment. Thankyou for any assistance that can be provided. EDIT: I have also followed the instruction for speeding up MSE here: http://www.brighthub.com/computing/smb-security/articles/69294.aspx, but I am not sure which files are meant by "Group Policy Registry Folder (C:\Documents and Settings\All Users)". Also, will this harm my system at all? Continue reading... Quote
