Guest AcetiK Posted March 29, 2012 Posted March 29, 2012 Environment : Windows 7 64-bits I'm using MDT 2010 for the deployment of Windows 7 in my school. A software that we use require a dll. If I use the following command under a classic command prompt it doesn't work: regsvr32 msstdfmt.dll /s. Actually, I need to use a cmd as Administrator for this work. I created a new application in MDT to deploy a script that will copy the dll file in the local system then I try to run the command to register the dll but the registration doesn't work. How can I force the command to be run as Administrator? Or, is there any other solution? Thanks in advance for your help, Continue reading... Quote
