Upgrade from 32bit to 64bit OS. Need advice
Guest NewsBot
My machine is running 32bit version of Windows 7 and I am considering upgrading it to 64bit system.
I had run Windows 7 Upgrade Advisor, the result showed that the system needs at least 2GB of RAM (the result is uploaded in the Skydrive link https://skydrive.live.com/redir?resid=CD59C312432E2341!110).
My concern is, apart from the RAM requirement, what else do I need to look into before I spend for the upgrade.
I also read an article that says, in order to run a 64bit OS, the processor must also be a 64bit CPU. How do I check that? Thanks
View the thread
