TheRedBaron Posted April 13, 2012 Posted April 13, 2012 The build: 99mm Sparks 12:1 37/31 Ferreas Kibblewhite Springs 208/921 DASA Intake DASA pipe cut 4" 43.5 FCR Stock ignition 91 pump gas Here is a file of the full pipe vs the cut pipe. [ATTACH]142.vB[/ATTACH] Quote Oscar L. 04 Demon 500R 64.9/40.9 91 Pump Gas
OTMTRX Posted April 13, 2012 Posted April 13, 2012 Nice... all bore on an 04.. different. Congrats.. Quote
Dr. Beardface Posted April 13, 2012 Posted April 13, 2012 Sweet. I'm thinking about doing something similar the next time I have to do a complete rebuild. I bet that's a blast to ride. Quote 2004 TRX480R 30+ HP
whoppes27 Posted April 13, 2012 Posted April 13, 2012 Nice! Is this still running on the stock rod? I've been considering doing a sparks 101 on mine down the road but I'm afraid the stock rod is too weak. As if the cylinder isn't expensive enough, a carrillo rod certainly isn't the cheapest either! Quote Racers Edge Powered 2006 trx450
junkie Posted April 13, 2012 Posted April 13, 2012 Very impressive pump gasser. Quote "I'd give my left arm to be ambidextrous.."
manny530 Posted April 13, 2012 Posted April 13, 2012 very nice numbers Quote EVERYONES FAVORITE MOD!!!! http://450rhq.com/data/MetaMirrorCache/f7e22d28ca03559ff7236e85f6128ca5.jpg
Guest Deven Posted April 13, 2012 Posted April 13, 2012 Great Looking numbers on a pump gasser... Quote
TheRedBaron Posted April 14, 2012 Author Posted April 14, 2012 Nice! Is this still running on the stock rod? I've been considering doing a sparks 101 on mine down the road but I'm afraid the stock rod is too weak. As if the cylinder isn't expensive enough, a carrillo rod certainly isn't the cheapest either! Yup, still running on the stock rod. Quote Oscar L. 04 Demon 500R 64.9/40.9 91 Pump Gas
want2bfast Posted April 14, 2012 Posted April 14, 2012 those are great numbers.. BEAST MODE.. Quote I dont ride dick? So whats your point?
TheRedBaron Posted April 14, 2012 Author Posted April 14, 2012 Thanks guys!! I just want to thank the Demon boys Morgan and Sergio!! I handed them my bike. Told them what I wanted and they built it. They did an amazing job with this build, I couldn't be happier!!!! Quote Oscar L. 04 Demon 500R 64.9/40.9 91 Pump Gas
