Motor Building Secrets
Morgan
Install your head assembly with the motor on TDC and install the cam gear and cam chain with the lines level with the arrows on the cam tower. Install the cam gear bolts and the timing chain tensioner, extend the tensioner to ensure it doesn't skip timing when you roll it over. With your 8mm allen you used eariler, roll the motor over slowly 2-3 full rotations. Remove the head in the opposite order you installed it, and we are now ready to see what we have for Piston to Valve clearance.
When the head is removed you will be able to see that the valves have left their indentions in the modeling clay. Take note of the outer edge to make sure the valves are inside the valve pockets and not hitting. Next, cut the clay in half from intake to exhaust not from intake to intake. Dished valves must be checked against the lowest point at the rear of the valve relief. The center will give you a false reading. Take your calipers and measure the piece that is still on the piston and record. The absolute bare minimum is .050 on the intake and .070 on the exhaust. With this DASA LL piston our intake was .075 and the exhaust was at .096, adequate room on both sides, with slightly more to allow for even more to be cut off the head safely then we already cut off.
Wiseco and JE shelf pistons usually do not have the valve relief that CP shelf pistons do. Most CP shelf piston will allow .010-.015 off the cylinder and .015-.020 off the head with adequate piston to valve clearance.
Morgan Russell
Demon Industries- Owner
Facebook- Demon Industries
Link to comment
Share on other sites
  • Replies 37
Great stuff!
Couple of questions if you don't mind. Do you stick with .040 on all your engines or does it vary by manufacturer/engine size? How much of an effect does this have on compression ratio, is the whole point of this to increase compression? What is the stock deck height set at?
2004 TRX480R
30+ HP
Link to comment
Hey morg, after removing .010-0.015 from the cylinder, is it enough to worrry about it affecting the cam timing, and to degree it, or is it minimal at that amount of material removed?
2004 Trx480R
Motowoz shocks and quad innovations arms
Rage Head, 12.5.1 Comp 480, Rossier Pipe, Dyna IGN
And countless other things over the years,
1995 Ranger, 6'' lift on 35's awaiting the transplant of a 400'' SBC
Link to comment
  • 2 months later...
  • 8 months later...
