grtrat1 Posted November 23, 2012 Share Posted November 23, 2012 Heres the story.... I need more time through the gears.... 13/38 I have to shift way too fast... 14/38 seems to be the happy medium... Problem... I broke my chain trashed the front sprocket..... Had a spare chin and a new 13 front sprocket... Bought the poly case saver.... No room for a 14 sprocket, Dont want to make room for the sprocket... Id rather have that protection over the sprocket... From a sprocket chart.... Running 14/38 is 2.71 Running 13/35 is 2.69 Is there a disadvantage of running a smaller than stock rear sprocket to gain alittle more top end??? So I can be back at my happy medium... By the way... My neighbors 06 450r kicker has the same 13/38 and he can go father between shifts than I can on my 13/38...Same size tires also... Need some opinions.... Quote http://www.offtopic.forum/images/sig.png Link to comment Share on other sites More sharing options...
bvet4dog Posted November 23, 2012 Share Posted November 23, 2012 got 12/38 (went done one front) and i seem to like it. Although i think i might want better low/mid range than top end. You seem to be looking for more top end. By not file the case saver a little. I dont see how that would ruin the strength of the gaurd unless you're really cutting alot out. I do want to change my gearing to something better too. I ride trails/sand pits not dunes. Kind of want to fix the problem with chain chewing up my chain guide. I dont think i have any other options lol. Quote 07 trx450r http://450rhq.com/data/MetaMirrorCache/cd3b5c0a9ec786930d0a92290fd034b5.jpg Link to comment Share on other sites More sharing options...
grtrat1 Posted November 23, 2012 Author Share Posted November 23, 2012 Need to go bigger in the front... The smaller sprocket is letting the chain slide on the guide all the time...Thats what Im guessing... Quote http://www.offtopic.forum/images/sig.png Link to comment Share on other sites More sharing options...
bigcountrydude Posted November 23, 2012 Share Posted November 23, 2012 good luck finding a 35 tooth rear. if you do its prolly gunna be a 2 piece sprocket and not cheap. personaly, i'd shave the case saver so the 14 fits. with properly maintained chain and sprokets with the right chain slack there is a very slim chance the chain will ever come off under normal riding conditions anyway. Quote Stock Bore, Stock Stroke, Pump Gas, and Kicking Ass TEAM JUNK RACING #224 Link to comment Share on other sites More sharing options...
grtrat1 Posted November 23, 2012 Author Share Posted November 23, 2012 Im not worried about it coming off.. I dont want it to break again.. Quote http://www.offtopic.forum/images/sig.png Link to comment Share on other sites More sharing options...
hoser Posted November 23, 2012 Share Posted November 23, 2012 What brand case saver? You shouldn't have a problem fitting a 14 on the front. And even if it takes a bit of grinding to make it fit the integrity of the case saver shouldn't be compromised at all. Quote Link to comment Share on other sites More sharing options...
grtrat1 Posted November 23, 2012 Author Share Posted November 23, 2012 What brand case saver? You shouldn't have a problem fitting a 14 on the front. And even if it takes a bit of grinding to make it fit the integrity of the case saver shouldn't be compromised at all. I got the Moose poly saver....It looks like there isnt much room between the chain and case saver... Quote http://www.offtopic.forum/images/sig.png Link to comment Share on other sites More sharing options...
Loud450man Posted November 24, 2012 Share Posted November 24, 2012 ^ no supposed to be thats the point..... Quote 450r mx quad ...sb, st, flux capacitor :headbang: Link to comment Share on other sites More sharing options...
ridingred Posted November 26, 2012 Share Posted November 26, 2012 it depends on the year, but i know for sure a 04/05 moose poly case saver has clearance for a 14t since that's stock. the 06+ might require grinding. Quote 05, 13:1 JE, 02 crf cam, full hmf, razr tt tires, rath sway bar, lowering link in the rear, triple rate rebuilds on front. Link to comment Share on other sites More sharing options...
grtrat1 Posted November 27, 2012 Author Share Posted November 27, 2012 Didnt need any grinding... Quote http://www.offtopic.forum/images/sig.png Link to comment Share on other sites More sharing options...
El Mamito USMC Posted November 27, 2012 Share Posted November 27, 2012 i run 14/37 and love it.. hate it with the 38, and to avoid chain braking get a DID chain and Tm chain guide .. or you can get the skid plate with the chain guide included in it.. Quote http://www.offtopic.forum/data/MetaMirrorCache/06f1a7ba567102d307e3f721efc437ad.jpg Zorros racing.. #123A - Baja 500, 2014 FINISHER !!! Subscribe to us on FB http://www.facebook.com/zorros.rt http://www.offtopic.forum/data/MetaMirrorCache/91c75944b97d47249f183869c9875a9e.gif http://www.offtopic.forum/data/MetaMirrorCache/5639c3ecf3b34b1f1e26b660950f9785.gif Join the http://www.Marines.com travel to exotic lands, meet exciting unusual people and kill them.. Link to comment Share on other sites More sharing options...
450Riot Posted November 27, 2012 Share Posted November 27, 2012 I've always run DID since the OEM wore out. TM Designworks makes a nice slide n' guide kit for sure. As far as gearing preferences I found a really nice setup with a complete stock engine with a Dasa in and out on a 14/39. Never rev out in 5th but 1st could be a little longer. Works nicely in 2nd to start though. Quote 2004 Honda Trx450Riot Kicker Dasa K&N Motul Kenda Pro Taper Motion Pro Streamline Blingstar Link to comment Share on other sites More sharing options...
