Ok, so I know with the HRC kits a replacement T vent comes with it, but i was wondering what size drill bit you guys are using on these, and if there is a noticeable increase in power from such a simple mod.
thanks.
05, 13:1 JE, 02 crf cam, full hmf, razr tt tires, rath sway bar, lowering link in the rear, triple rate rebuilds on front.
  • Replies 4
no power increase. it just allows the crankcase pressure to vent
  • Like 1
Check out our website and shopping cart: Woodward Specialties
The site has been completely redesigned and updated with thousands of products, more being added daily!
Use discount code: 450RHQ
Paypal can be sent to: Paul@woodwardspecialties.com
Email me- Paul@woodwardspecialties.com
Please: If you have questions, PM or email me
[broken External Image]:http://img.photobucket.com/albums/v3.../woodward1.gif
I can see why honda made a new T breather to go with hrc power up kit. I didnt get one... what sizes drill bit should i use? I wouldnt know how much i need to cut out, so that's why i asked on sizes on the bit.
07 trx450r
http://450rhq.com/data/MetaMirrorCache/cd3b5c0a9ec786930d0a92290fd034b5.jpg
I think I used a 3/8 reamer on mine, I read somewhere to just make the hole the same size as the largest diameter hole on the tee, if that makes sense
  • Like 1
http://450rhq.com/data/MetaMirrorCache/92ac89484251c63d73340458b54ac18b.jpg
By alanbmx at 2012-04-16
thanks alan. I'm gonna see if a 3/8 bit goes into the biggest hole and if so i'll just drill the rest out.
