I've been wanting to clean up my handle bars, by removing the light and kill switch cluster. So I started to tackle it this weekend. I thought I had it figured out, with these drawings, but I must be missing something.
The kill switch is easy, just leave the black/white and green wiring disconnected, using the key switch will be your on/off. As far as the lights, I want the high beam and the on postion to work together, I don't need
the low beam. The switch has an internal light, for on postion, I don't need that option. Any one see a problem with this concept? Thanks for your input. :gr_wink:
04/05 Wiring Diagram
http://www.offtopic.forum/uploads/imported/2013/04/98231A0CF4B249F2B0A06FE597E0434B11630000-1.jpg
The Switch To Be Used
http://www.offtopic.forum/uploads/imported/2013/04/9256382CE3844BB6B5BE9FB7EA49E86F11630000-1.jpg
http://450rhq.com/data/MetaMirrorCache/be5b07af4c27fc1c6c9beaaea87ef233.jpg
  • Replies 6
Stewart, Do you still have that diagram you drew up for me? I'll look for it...
It was a little different from what you're doing Fred, It used a 3 way switch hi/off/low but you could probably figure out how to wire both on and use a 2 way. I'll see if I can find the drawing.
Live Free or Die
http://450rhq.com/data/MetaMirrorCache/9429fda0882ce39582aff21a740157c0.gif
Here's the drawing I did for Ed mate... not sure if it'll help but may give you some ideas.. ? I'm off work from Wed am onwards so can draw you up something if needed then, I'm not going to get much time before then.
Have a look, see if it helps at all and throw out any questions you have..
Sorry it's a bit rough, it was done for Bailey, he's not as refined as yourself, so please make allowances...:rotflmao:
http://www.offtopic.forum/uploads/imported/2013/04/05TRX450rLightswwiring-1.jpg
Here's the harness I made up using the stock plugs / wires to make it easier to fit etc..
http://www.offtopic.forum/uploads/imported/2013/04/Picture187-1.jpg
And the switch mounted under hood. Toggle left for High, right for low, centre pos is Off.
http://www.offtopic.forum/uploads/imported/2013/04/Picture191-1.jpg
lol, thanks stew! F*ck your diagram I have a horse outside! lmao
Fred, I have a switch with wires already on it if you want it. All youd have to do is splice your wires from the switch to it. Stew sent me a couple when I did my 04.. Then you could do exactly what's pictured above and keep both high and low beams.
Live Free or Die
Thanks guys for your help. I think I may have found my problem. When I cut the harness off, there were two ground wires going to the cluster. One going to the kill switch, the other one spliced to the ground wire. I believe that splice
feeds the lights, therefore I need to connect these two grounds together. (As Shown) I'll try it tonight. Thanks again guys!
http://www.offtopic.forum/uploads/imported/2013/04/null-1.jpg
Ground shown feeding the lights.
http://www.offtopic.forum/uploads/imported/2013/04/WiringLightsGround1-1.png
