OTMTRX Posted May 17, 2013 Share Posted May 17, 2013 Got this on a bike I picked up a while ago.. Guy said it was a Dominator but I have Dominator II's on both my rear ends and it's different (and no laser etching, but don't know if the Dom 1 had etching or not). Stock length is 29" from inner hub flange to inner hub flange, this is 30.5" with approx 1.5" of spacers (note the chamfer) on each end so I'm guessing it gets sold as a +1 to +4. It has a serial number on it ( 350876 P100499 ) but I can't find anything from a google search. The only other markings are "450R" on the hub, the hub is a clip type hub, rather than the pressed on, that I do recognize, but can't remember where from.. I had an LSR before my Dom's but that had a pressed on hub too.. The hub has wear on it from bad carrier bearings.. Any help appreciated.. http://www.offtopic.forum/uploads/imported/2013/05/D39B381BF5D246EFBEAA466DB20844AA23800000-1.jpg http://www.offtopic.forum/uploads/imported/2013/05/7ADA2496A8ED483A9F48C6124071BF5623800000-1.jpghttp://www.offtopic.forum/uploads/imported/2013/05/11DBE69121A34AE182A8CACD15B9FEC923800000-1.jpghttp://www.offtopic.forum/uploads/imported/2013/05/77CD2ED3D75F4F099DC7A61861E76BF723800000-1.jpg http://www.offtopic.forum/uploads/imported/2013/05/AD53563592B04B3C838204B8868EEB4B23800000-1.jpghttp://www.offtopic.forum/uploads/imported/2013/05/491A97AB2D4B435FA9B90576A172D2B823800000-1.jpg Quote Link to comment Share on other sites More sharing options...
ridingred Posted May 17, 2013 Share Posted May 17, 2013 it looks like an rpm axle, but the hub there is not the same as the rpm's i've seen. spacers and axle itself look very similar to rpm. Quote 05, 13:1 JE, 02 crf cam, full hmf, razr tt tires, rath sway bar, lowering link in the rear, triple rate rebuilds on front. Link to comment Share on other sites More sharing options...
chronicsmoke Posted May 17, 2013 Share Posted May 17, 2013 def. not a Dom. II You using it or selling it Stew? Quote CRASHTEST RACING IMMORTAL ATV http://www.offtopic.forum/data/MetaMirrorCache/7cbc5acb2a1ab76eac286e7fe5b4520d.jpg Link to comment Share on other sites More sharing options...
Baileyguns Posted May 17, 2013 Share Posted May 17, 2013 Its an older durablue, no? Quote Live Free or Die http://450rhq.com/data/MetaMirrorCache/9429fda0882ce39582aff21a740157c0.gif Link to comment Share on other sites More sharing options...
ridingred Posted May 17, 2013 Share Posted May 17, 2013 the older durablu's did not use splines. i know they got rid of that older design because it was problematic, and it was i kept bustin pins on my hubs with the older durablu axles. Quote 05, 13:1 JE, 02 crf cam, full hmf, razr tt tires, rath sway bar, lowering link in the rear, triple rate rebuilds on front. Link to comment Share on other sites More sharing options...
Baileyguns Posted May 17, 2013 Share Posted May 17, 2013 the older durablu's did not use splines. i know they got rid of that older design because it was problematic, and it was i kept bustin pins on my hubs with the older durablu axles. You're a fucking idiot... I took off the ignore feature just to see what you wrote. The X-33 is the axle that uses the pins and they still offer it. The rest of the Durablue axles (new and old) use splines on the end just like all the other axles out there. Every time you try to sound smart, you sound more like an idiot. You're so ramped up on trying to prove people wrong that you don't even take the time to make sure you're correct before you spout off. Here... School yourself, 3 axles to choose from. http://www.durablue.com/prod_display/axles/5/0.php.htm 1 Quote Live Free or Die http://450rhq.com/data/MetaMirrorCache/9429fda0882ce39582aff21a740157c0.gif Link to comment Share on other sites More sharing options...
chronicsmoke Posted May 17, 2013 Share Posted May 17, 2013 You're so ramped up on trying to prove people wrong that you don't even take the time to make sure you're correct before you spout off. This.. and it's gotten really bad lately.:nono: Just join the crew and slap him on 'ignore' it works great Quote CRASHTEST RACING IMMORTAL ATV http://www.offtopic.forum/data/MetaMirrorCache/7cbc5acb2a1ab76eac286e7fe5b4520d.jpg Link to comment Share on other sites More sharing options...
Baileyguns Posted May 17, 2013 Share Posted May 17, 2013 Oh... He is and has been. Quote Live Free or Die http://450rhq.com/data/MetaMirrorCache/9429fda0882ce39582aff21a740157c0.gif Link to comment Share on other sites More sharing options...
hoser Posted May 17, 2013 Share Posted May 17, 2013 Good thread from the ORG. Click Quote Link to comment Share on other sites More sharing options...
Baileyguns Posted May 17, 2013 Share Posted May 17, 2013 No way Hoser!! the last 3 numbers don't match! lol Quote Live Free or Die http://450rhq.com/data/MetaMirrorCache/9429fda0882ce39582aff21a740157c0.gif Link to comment Share on other sites More sharing options...
OTMTRX Posted May 17, 2013 Author Share Posted May 17, 2013 Good thread from the ORG. Click Perfect! Thanks mate.. that's the one.. and the stock hubs don't fit... yep it's for sale Chronic! Cheers Ed / Dave too.. Quote Link to comment Share on other sites More sharing options...
hoser Posted May 18, 2013 Share Posted May 18, 2013 No way Hoser!! the last 3 numbers don't match! lol Crap, and I thought I had it figured out lol! Quote Link to comment Share on other sites More sharing options...
hoser Posted May 18, 2013 Share Posted May 18, 2013 Perfect! Thanks mate.. that's the one.. and the stock hubs don't fit... yep it's for sale Chronic! Cheers Ed / Dave too.. No problem Stew!! Man, you got axles coming out your ears lol. I did finally round up an RPM for my MX/Sand quad, unfortunately I had to buy it new, but Jeff and Roni gave me a good deal. Quote Link to comment Share on other sites More sharing options...
OTMTRX Posted May 18, 2013 Author Share Posted May 18, 2013 Lol Cheers Hoser.. Glad you got your RPM eventually.... Quick search bought up a few places that may sell hubs for it.. I'll call around next week and see if anyone actually has them.. I'm amazed at your Org knowledge too mate.. You can a pull an old thread up from anywhere eh? lol... Thanks again! 1 Quote Link to comment Share on other sites More sharing options...
