ghott Posted November 25, 2013 Posted November 25, 2013 I have a bunch of parts that I need to sell. These parts are a mixture of parts taken from the stock bike that I tore down to turn into a drag bike and parts that I've had in storage for quite a while. First and foremost - the prices do NOT include shipping and do NOT include PP fees. Buyer will cover the PP fees or can gift the payment to save the hastle. Shipping will be anywhere from $2 to $95 depending on the part's size and weight. The prices listed are for local pickup only...which is preferred for the larger/heavier items. I like to take a lot of pictures of items I put up for sale so there are no surprises for buyers. I have a total of 194 pictures for the items below; that's way too many to post in a thread...so I just uploaded them all to a photobucket gallery. See the link below for all the pictures. Detailed pictures of all items here: http://s288.photobucket.com/user/ghott01/library/fall2013sale Some of this stuff...I don't really know what it's worth; so feel free to offer. - OEM 04/05 Exhaust Header Pipe - $10 -- Dirty and rusty but worked well in conjunction with the FMF silencer listed below - OEM 04/05 Ignition - $20 -- Works great, just dirty - OEM 04/05 Oil Cooler (w/ lines, o-rings, shroud, and mounting bolts) - $35 - OEM 04/05 Top Motor Mounts (complete with bolts) - $15 - OEM 04/05 Radiator w/ Cap - $25 -- She's dirty and has many bent fins; also dented on top-right side; no leaks - OEM 04/05 94mm Piston w/ Pin and Rings - $5 -- No clue if this is in spec or not? - OEM 04/05 Parking/E-Brake Complete Setup w/ Cable - $10 -- Great shape, little dirty, has silver spray paint over-spray on it - OEM 04/05 Head Light - $75 -- Comes with mounting brackets and bulbs - worked on high and low beam - OEM 04/05 Rear Shock - $25 -- Inner plastic shroud is cracked; has silver spray paint over-spray on it - OEM 04/05 Complete Rear End Setup - $95 -- 04/05 Swing Arm w/ Hardware -- 04/05 Axle w/ lock-nut, brake caliper, stay, hubs, sprocket mount, carrier, and bearings -- Good shape and worked well; just dirty - Chain and Sprocket Set (nice set) - $30 -- 13T Front Sprocket -- 38T Rear Sprocket -- 94 Link RK EKW X-Ring Chain w/ Master Link - Ohtsu M/R 501 Rear Tires - 20x10-9 - $100 -- Great shape; no plugs, rips, tears, or leaks -- Approximately 80-85% tread life left -- Great tires for trails, sand, drags, hill-climbs, etc. - 04/05 Wicked Motors, MD Ported Cylinder Head - $400 -- This is the head I used from 2008 - 2012; it's cut for 37/31 valves (+1mm in all 4) -- It has epoxy on the floor and roof of the intake port and in the exhaust port also (not posting pics, sorry) -- It made 56hp/36tq as a stock bore/stroke with a small DASA filter, 43.5mm FCR, HC Stage 3, full length DASA, and crappy Sunoco 110 fuel (see dyno sheet for proof) -- It received new KW +1 valves in 2012; which now have 1 season of racing on them (included, but not sure if they are still in spec?) -- Head is decked .060", received a Serdi valve job in 2012, and I THINK it has bronze guides and copper berrylium seats (can't remember for sure tho) -- Perfect head for use in conjunction with a DASA Loretta Lynn's piston - CP M2035 94mm 12:1 Piston (used for maybe 4-5 hours total) - $95 -- With Wrist Pin, Original Box, etc. -- No clue if this is still in spec - but it definitely should be - Rage CP 13:1 Race 94mm Piston for Decked Heads - $45 -- Nicely designed piston for plenty of clearance with .060" off a head (makes for 15:1+ comp) -- No clue if this is still in spec or not - FMF Factory 4 Slip-on Silencer w/ Rear Mount - $25 -- Rougher shape with scratches and a small dent - still sounded pretty good tho Quote Gary My 2005 Honda TRX450R Site (^^^TRX450R tech articles, dyno testing, pics, vids, and more) http://450rhq.com/forum/data/MetaMirrorCache/993866a3d66db74390c422c8723b1a16.jpg | '04 Racers Edge, AZ 545cc "Me Gusta!"|||| '05 Wicked Motors, MD 450cc "PunisheR" |
ghott Posted November 30, 2013 Author Posted November 30, 2013 Updated Quote Gary My 2005 Honda TRX450R Site (^^^TRX450R tech articles, dyno testing, pics, vids, and more) http://450rhq.com/forum/data/MetaMirrorCache/993866a3d66db74390c422c8723b1a16.jpg | '04 Racers Edge, AZ 545cc "Me Gusta!"|||| '05 Wicked Motors, MD 450cc "PunisheR" |
ghott Posted December 12, 2013 Author Posted December 12, 2013 Removed everything that is sold. Still some stuff for sale! Quote Gary My 2005 Honda TRX450R Site (^^^TRX450R tech articles, dyno testing, pics, vids, and more) http://450rhq.com/forum/data/MetaMirrorCache/993866a3d66db74390c422c8723b1a16.jpg | '04 Racers Edge, AZ 545cc "Me Gusta!"|||| '05 Wicked Motors, MD 450cc "PunisheR" |
