Yes, in your USERCP go to "EDIT OPTIONS" and highlight MULTIPLE forums towards the bottom by using the CTRL key while dragging over them. You'll need to use the DEFAULT theme in order to see the HIDE FORUMS options.In "Todays Posts" is there a way to choose what is shown? Like take the alt. forums out. I've checked USERCP and can't find the option.
can we bring that back?Personally, I'm hooked on the old black and grey classic theme..
If I remember correctly, Bob is working on a GF Classic theme that also includes having the forum setup just like it did back in the day when you first came here.can we bring that back?
When I put it on black, there was orange.It would if it had orange or yellow in. I've never seen blue associated with halloween before.
That must be a browser issue. I can see them fine. All users are white text.Now BLACK BLUE I can live with. The only thing is, I can't see names of premiums in the shoutbox. Fix that prob and you found yourself a winner..
I've always had that problem sense we changed the last time. I haven't used dark since becuse of that. It's like that on all 4 cp's I use and in IE and Firefox. I'm not for sure about Oprera. I uninstalled that browser.Now BLACK BLUE I can live with. The only thing is, I can't see names of premiums in the shoutbox. Fix that prob and you found yourself a winner..
