L
LadyMartel4000
"Mike Hall - MVP" wrote:
> "LadyMartel4000" <LadyMartel4000@discussions.microsoft.com> wrote in message
> news:C6EA1B63-3627-46A5-936E-2C8CCF3E9BE8@microsoft.com...<span style="color:green">
> > Thanks Mike and Paul, I did what you two told me to do but unfortantly
> > it's
> > still not working!
> > I readed the manuel and checked out to see if it was disabled or not. It
> > says: AC97 Audio Controller - Able. Therefore I'm guessing that isn't the
> > actual problem.
> > I tried installing the driver-which actually IS a problem...
> > There are two install files from the download...I tried to install them
> > both. One file (from W2k_XP) doesn't work. I click on it, it asks if it
> > should let it run I click yes-nothing happens. I click it again-go through
> > the same process and nothing happens. I go over to the other one (from SE)
> > I
> > click install and allow...a message pops up saying: 'Cannot Open Key' and
> > it
> > keeps giving me these messages under the 'Cannot Open Key' part but every
> > message is slightly different from the last one and I can't get it off
> > until
> > I restart the computer again. This the the 1st three messages I get from
> > it-I
> > hope it helps!
> > 'Cannot Open Key'
> > ENUMACPIFIXEDBUTTON2&DABA3FF&0
> > 'Cannot Open Key'
> > ENUMACPIGENUINEINTEL_-_X86_FAMILY_15_MODEL_21_0
> > 'Cannot Open Key'
> > ENUMACPIPNP0000471BF87COF&0
> > From then on ENUMACPIPNP stays the same.
> > I hope those messages help!</span>
> There is a good chance that the integrated sound card is a goner if the
> drivers from Asus do not work.
> However, there is something else you can try..
> Go to Control Panel > System > Hardware tab > Device manager button..
> Scroll down the list of devices until you reach the sound section.
> Now uninstall all of the sound section, and then reboot your computer. It
> should detect that there is no sound card and drivers, and attempt to
> install whatever it can find. If drivers are not found, run the drivers from
> the Asus web page for W2k/XP. You may just get lucky.
> If this fails too, buy yourself a PCI soundcard and install it. You will
> have to go into BIOS and disable onboard sound even though it may not be
> working properly..
> Good luck
> Mike Hall - MVP Windows Experience
> http://msmvps.com/blogs/mikehall/
Ok I've uninstalled all of the sound programs possible (though for some odd
reason I couldn't uninstall: Audio Codecs, Legacy Audio Drivers, Media
Control, Standard Game Port and Video Codecs.) I did uninstall Unimodem
Half-Duplex Audio Device but for some odd reason when I rebooted the computer
it is automatically already installed back in again.
A couple of days ago I was looking around in the add/remove programs and I
found out that I have Service Pack 2 and 3 installed. Is that ok or can they
corrupt one another?
> > it's
> > still not working!
> > actual problem.
> > I
> > it
> > until
> > it-I
> > hope it helps!
> > 'Cannot Open Key'
> > 'Cannot Open Key'
> > 'Cannot Open Key'
> working properly..
> Good luck
