  • Replies 5
Just a typo as far as I can see.
Discus....a thing you chuck across a field
Discuss....to interact verbally (or by typing)
Apart from that, the site looks great. Now how about enabling animated gifs to be used in the signature line.....pleeeeeeeeease? :)
Dementia is just a state of mind.
I'll fix it. Animated avat.ars are enabled. Maybe the size limit is the problem. What is the dimensions of the image and the size?
Only a typo as far as I can see:
'Discus' should read 'discuss' - in the title line of the forum.
Aparr from that, site looks great. Now how about enabling animated gifs in the signature line.....pleeeeeease?
Guest skategreen
On "that other site" I never had the trouble of being "kicked out" if I left in the middle of a reply and then came back to it ten minutes later.
It happened twice today. First time caught me unawares, next time I was savvy enough to hit ctrl c prior to hitting submit.
I logged on..started composing..got interrupted, came back to reply, finished typing, hit 'submit', and the reply was lost as I was not "logged on".
perhaps a glitch?
  • 3 weeks later...
I missed this. When you login make sure you tick remember me. Otherwise the login will deactivate after 15 minutes.
