ok, i had this siggy made at another lp forum, and i used it here and it was fine, then i got another siggy, then i wanted to use the first one again and it said it had too many characters, and i was wondering y i could use it once, but now i can't, :confused:
well heres the siggy:
It's crawling inside, it's something I can't define.
It feels like a stranger, but it's more than ( i n t a m a t e . )
This time is infact ( i m p e r f e c t . )
http://www.sucksbbs.net/data/MetaMirrorCache/bb2dcf01aaef6417df375864d8457158.gif
myspace|peta2
  • Replies 6
The max characters for a sig has been 250 for a few months now. I can't remember the exact date.
It just means you need to cut down on the amount of letters you're typing.
You may want to try converting those color codes into text. "" could be
I can also see alot of spaces in it, those count as characters also.
[broken External Image]:http://img168.exs.cx/img168/6938/alliedv60em.gif
No matter what you see, you're still so blind to me.
