ImWithStupid
Well-Known Member
- Joined
- Sep 17, 2005
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Before I commit to paying higher taxes and energy bills the Goreist's need to show the preponderance of the evidence shows:
1) The Earth is warming. (It has not since 1998)
2) A significant part of this warming is due to usage of fossil fuels.
3) That the benefits from reducing the damages caused by global warming will outweigh the huge costs to economies that will be incurred in taxing and regulating fossil fuel usage. (Many believe global warming will be a net benefit to mankind, more food for the growing population. Who can be against that?)
4) That it is possible for worldwide cooperation that actually reduces global warming significantly.
Fact, every person pushing this 'man caused global warming' agenda has political or financial gain as their reason.
Really? Every single one? It would take a lunatic to believe that.
The fact is CO2 is a greenhouse gas which means there is a positive correlation between higher CO2 content in the atmosphere and warmer temperatures. The questions are 1) How significant is CO2 as a greenhouse gas 2) What other factors could multiply or diminish the warming effect of CO2 and 3) What politically possible options are available to diminish CO2 in the atmosphere if it is deemed a real threat. In my opinion the only way to diminish CO2 in the atmosphere, given the economic rise of the developing nations, is to find energy sources that are as cheap as those that produce CO2 emissions. If the Western world simply reduces emissions by artificially equalizing the cost of oil and coal with cleaner energies it will do very little to combat the issue of CO2 emissions worldwide.
The temperature of the surface of Venus right now is about 850 degrees farenheit.
The temperature of the surface of Mercury right now is about 350 degrees farenheit.
That said, we should be the best stewards of the earth and yearn for the most responsible means of existence as possible without destroying ourselves in the process.
The Space and Science Research Center (SSRC), the leading independent research organization in the United States on the subject of the next climate change, issues today the following warning of imminent crop damage expected to produce food and ethanol shortages for the US and Canada:
Over the next 30 months, global temperatures are expected to make another dramatic drop even greater than that seen during the 2007-2008 period. As the Earth’s current El Nino dissipates, the planet will return to the long term temperature decline brought on by the Sun’s historic reduction in output, the on-going “solar hibernation.†In follow-up to the specific global temperature forecast posted in SSRC Press Release 4-2009, the SSRC advises that in order to return to the long term decline slope from the current El Nino induced high temperatures, a significant global cold weather re-direction must occur. According to SSRC Director John Casey, “The Earth typically makes adjustments in major temperature spikes within two to three years. In this case as we cool down from El Nino, we are dealing with the combined effects of this planetary thermodynamic normalization and the influence of the more powerful underlying global temperature downturn brought on by the solar hibernation. Both forces will present the first opportunity since the period of Sun-caused global warming period ended to witness obvious harmful agricultural impacts of the new cold climate. Analysis shows that food and crop derived fuel will for the first time, become threatened in the next two and a half years. Though the SSRC does not get involved with short term weather prediction, it would not be unusual to see these ill-effects this year much less within the next 30 months.â€
