W
What Me Worry?
"Phlip" <phlipcpp@yahoo.com> wrote in message
news:W4yZh.1850$RX.1596@newssvr11.news.prodigy.net...
> What Me Worry? wrote:
>> You see, if it had happened as you say, then the floors would have slid
>> down the giant central core (severing at the inner and outer connection
>> points) leaving the core standing . From the numerous videos of the
>> collapse, we see the entire structure shattering to dust and giant
>> neatly-severed steel columns being catapulted upward and outward
>> hundreds of yards, smashing into neighboring buildings. The 47 giant 4"
>> thick steel box columns and all of the beams and outer "sleeve" of
>> structural box columns all shatter and fall at the same rate. There was
>> nothing left of the core except a pile of neatly-severed 30 ft sections
>> of 22" wide 4" thick box columns. There is simply no way that your
>> theory can fit with the well-documented evidence.
>> There is a theory that does fit the evidence, however...
> Yes. The steel floor trusses until they expanded, forcing the outer
> columns out and initiating the collapse. Once it happened, the energy of
> all those tons of concrete and steel, in motion, far exceeded their
> resting energy, so they plowed through the rest of the building, exploding
> it outwards. And the inner structure can be seen still standing as the
> floors and outer structure peel away. Exactly the opposite of a controlled
> demolition.
NIST won't go there. Their computer simulation doesn't include the bottom
60+ floors of the WTC towers, which were 100% intact at the time of the
collapse. The NIST report doesn't even attempt to explain the actual
collapse (as you have tried to do.) NIST doesn't know why the WTC towers
collapsed. They've rejected the thoroughly-discredited "pancake theory,"
which you appear to be espousing. Perhaps you didn't know it's out of vogue
among the "true believers."
> demolition.
