Baileyguns
Active Member
- Joined
- Apr 28, 2012
- Location
- New Hampshire
Those Tusk HD springs are junk... I used them for a bit and they fade out when they get hot. I'm happy I have a quick adjust on the clutch because I would have to constantly adjust it with the heat of the engine. I haven't had an issue with the Tusk fibers yet and they are a bit cheaper then the OEM fibers.
Fred, DS is gone now right? I'll look into the Tokyo springs, Ghott I think did a write up on a bunch of springs and said the LTR springs are good too if I recall correctly. I'll have to look and see if I can find it... I bet its on his site.
